Asus X552L Only Work On Battery (need BoardView)
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    This asus with X550LD REV.2 Motherboard.
    I don't get any 5V or 3.3V with charger, but if i use a charged battery, the Laptop works 100%.
    I suspect that a Mosfet is dead, but without schematic or boardview it's difficult.
    Help guys
  • JaroTech
    • Mar 2015
    • 351
    Re: Asus X552L Only Work On Battery (need BoardView)
    Hi, I have only the repair guide, I hope it will be useful.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      use asus ux31a2 schematic as reference.
      almost all of asus give name for component always same at many board. the different was location/position of those on PCB.
      charging chips look seem was BQ735, so acfet and rbfet are pq8801 and pq8802
      scan photo x550ld: http://rusfolder.com/43774232
      credit : gs84 and notebook1.ru
      • maxnaruto
        • Nov 2015
        • 6
        • Ghana
        try this jumper in the picture but make sure 19v is present on RHS of the jumper but absent on the LHS.
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          What is RHS and LHS ?
          • maxnaruto
            • Nov 2015
            • 6
            • Ghana
            i mean right hand side (RHS) and left hand side (LHS) of the jumper
            • maxnaruto
              • Nov 2015
              • 6
              • Ghana
              Sorry for the image quality please bear with me.
              • passete
                Living=Sharing
                • Jun 2015
                • 487
                • France
                Well, your Mobo is not the same !
                Anyway, i have tested your "bricolage", and i still don't get any voltage on the bios chip.
                I guess that i will not risk turning it ON ...
                EDIT: I have 3V on Power switch, i guess that i will take a chance !
                Tell me, will this bricolage charge the battery ?
                • maxnaruto
                  • Nov 2015
                  • 6
                  • Ghana
                  i am very sorry.JaroTech sent x550LD repair guide so i thought your mobo was the similar.
                  it wont charge the battery until you identify and replace faulty component (in my case 2 mosfets close to charging connector )
                  • JaroTech
                    • Mar 2015
                    • 351
                    @passete, could you take a good picture of each side of the motherboard, so we can see what you have?
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      The first picture you posted is the good one, but your photo with the jumper soldered, doesn't have have discrete Nvidia chip.
                      Anyway, i went ahead and the mobo turns on and works with charger now, but like you said it doesn't charge.
                      Can you point on the first picture you posted, which mosfets do i need to replace ?
                      @jarotechn it's the same as the one first posted by maxnaruto
                      • dycc
                        Vision
                        • Nov 2011
                        • 624
                        • Côte d'Ivoire
                        which charging chip your mobo use ???? BQ24725 BQ24728 BQ24738 ???
                        • maxnaruto
                          • Nov 2015
                          • 6
                          • Ghana
                          my macbook os x wont boot otherwise i would have sent you x550ld schematics to help you identify faulty component.
                          • maxnaruto
                            • Nov 2015
                            • 6
                            • Ghana
                            @passete please take note you need to check with schematics to identify which mosfet is leaking or which other component(battery charger ic , resistor ,capacitor etc) is faulty.i want to believe this problem is common on X550** mobo so perhaps changing the same component may solve the problem.(remember to disconnect jumper after replacing faulty component)
                            • MadalinJula
                              Madalin
                              • Dec 2016
                              • 8
                              • Romania
                              I need bios for ASUS X550JD - REV 2.0!
                              Please help me guys!!
                              • DS-1
                                • Jun 2015
                                • 82
                                • Italy
                                @maxnaruto,
                                I have an Asus laptop with x550ld board with no Power at all. I've tried the jumper between the two pins indicated and the laptop starts with green leds for a second, then shuts off.
                                Can you help me fixing It? Thanks!
                                • dhenion
                                  Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                  by dhenion
                                  I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                  The original board was:
                                  ASUS X510UNR REV 3.0 A
                                  The replacement board is:
                                  ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                  It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                  01-30-2024, 01:45 PM
                                • rob777
                                  Asus TUF won’t run off battery
                                  by rob777
                                  I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                  I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                  Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                  Thanks....
                                  05-27-2025, 07:07 PM
                                • dhs6512
                                  Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
                                  by dhs6512
                                  Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
                                  Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
                                  Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
                                  When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
                                  Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
                                  When connecting...
                                  10-29-2024, 11:04 AM
                                • Iherduleikgemz
                                  Asus FX505DY - Battery not charging - BQ24780S
                                  by Iherduleikgemz
                                  Hello everyone
                                  I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                  I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                  01-13-2025, 03:54 PM
                                • cope
                                  Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                                  by cope
                                  I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                                  Some history:
                                  Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                                  As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                                  Now, with a new battery the system will start up and run off...
                                  05-13-2024, 09:40 AM
