dead acer e5-411
  • mangtomas
    • Jun 2014
    • 63
    • philippines
    dead acer e5-411
    need help from the experts, I'm fixing a laptop Acer e5-411 mobo is da0zqmmb6f0 rev:f that is dead. anyone out there has an schematic diagram,that would be a big help thanks
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Re: dead acer e5-411
    first check main power line,than look for 3,3 and 5v, and try to flash bios...
    not sure if it is correct dump but you can try...
    or post old bios dump so we can fix it...
    • mangtomas
      • Jun 2014
      • 63
      • philippines
      its hard to determine where is the problem because I have no reference, can someone provide me a schematic diagram of it, thanks
      • mangtomas
        • Jun 2014
        • 63
        • philippines
        I think its not bios because i cant even switch on the laptop so i think this might be a power problem
        • dj_ricoh
          • 2073
          dude BIOS makes the notebook dead. EVEN charging LED.
          now check every component and coils for short to GROUND.
          Inject voltage there if you find any. check and see if it gets hot.
          If you find that HM Chipset gets hot , your done BGA work required.
          start with bios and check with oscilloscope
          • ivanxxx
            • Nov 2012
            • 10
            • Croatia
            true...
            first search sieguntur repair on youtube videos for better understanding of mobo architecture then you can start repairing
            • mangtomas
              • Jun 2014
              • 63
              • philippines
              I think this is not a bios problem because there is no 19v in PQ26 which is n-channel power mosfet, there should be 19v in there I think but I only got 1.3v. If I don't have 19v in mosfet of 3valw and 5valw it will not generate 5valw and 3valw and 3valw is the supply voltage of bios for it to function so that's why I think its not a bios problem.
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                More Info:
                E5-411 Have bios chips low voltage just 1.8v, see datasheet winbond 25q64fws1g
                • polytek
                  • Dec 2013
                  • 496
                  • TUNISIA
                  Originally posted by meritosari
                  More Info:
                  agree with you meritosari, and most of them are (OTP)
                  see picture
                  • joselito
                    • Mar 2015
                    • 50
                    • Philippines
                    HI.. Good Day. Anyone have schematic for this DA0ZQMMB6E0 Rev:E
                    have some burned capacitor in 19v line. need to check value and to trace other problem in affected area. thank you..
                    • joselito
                      • Mar 2015
                      • 50
                      • Philippines
                      Re: Da0zqmmb6e0 rev:e
                      HERE is the picture of what i need. but if theres an schematic please..
                      • smali
                        • Sep 2014
                        • 287
                        • Pakistan
                        which laptop? brand and model
                        • joselito
                          • Mar 2015
                          • 50
                          • Philippines
                          shorted 19v line. i traced that PC 112 is shorted. i need to now exact value of that caps..
                          thank you,
                          • meritosari
                            • Oct 2010
                            • 774
                            • Indonesia
                            Use Quanta ZHK as refer :http://www.s-manuals.com/motherboard/quanta_zhk
                            the caps value are:
                            - 0.1U/25V_4 (0402)
                            - 2200P/50V_4 (0402)
                            How could be?
                            Quanta ZHK and ZQM using same IC NB671L
                            you'll find it at your donor board.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1489
                              • portugal
                              does capacitors ,. are not so needed o does part of the circuit , machine can live without them !!!
                              schematic and boardview
                              • joselito
                                • Mar 2015
                                • 50
                                • Philippines
                                Thank you very much.. appreciated..
                                Laptop is fixed now.. thank you guys..
                                • joselito
                                  • Mar 2015
                                  • 50
                                  • Philippines
                                  i already remove that so i confirmed PU6 is already shorted,
                                  got lucky i have spare of that NB671LGQ Z NB671L AJPE.
                                  thanks to all.
                                  • ry x hunter
                                    • Jun 2013
                                    • 184
                                    • philippines
                                    E5-411 schematic
                                    hi guys i need schematic diagram for my acer e5-411..thanks
                                    • HarryPK
                                      • Mar 2014
                                      • 210
                                      • barabai
                                      Schematic please
                                      • HarryPK
                                        • Mar 2014
                                        • 210
                                        • barabai
