Ive looked all over. Maybe someone knows where or a board schematic close to this that I can use to for diagnosis.
Need schematic Asus G46VW Board YR-4R 1 94V-0 E114139
Re: Need schematic Asus G46VW Board YR-4R 1 94V-0 E114139
Does anyone know if there is a schematic or board diagram for the Asus Rog g46vw laptop? I have not been able to find anything. Any help would be appreciated Thanks in Advance! -
Need schematic Asus G46VW Board YR-4R 1 94V-0 E114139Comment
Actually I managed to dig something up. There's some kind of metadata in it from laptop-schematics.com which is pretty bothersome, but it works and seems to be the right thingAttached FilesComment
I don`t know if this one is any good.Attached FilesComment
There's usually no schematics for recent Asus laptop but sometimes you can get the boardview which is of great use.
If you really need a schematics for reference, you may use the UX31A for example. (charging circuit is often similar for example).
The one you linked above is very old, UX31A is a bit newer. (at least it doesn't have northbridge+southbridge)OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
"The one you linked above is very old, UX31A is a bit newer. (at least it doesn't have northbridge+southbridge)"
I didn`t look at the boar dview,just uploaded it here
I was talking about the schematics PDF linked above, your boardview is probably fine (I didn't take a look at it either)
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by DynaxSCHi,
I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
The situation looks like this:
After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
1. RTC oscillates normally (32.768KHz).
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by ShadowAi12Hi,
I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.- The board enters a "ready to power on" state after plugging in the PSU.
- Pressing the power button increases power draw.
- Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
(taken after pressing the power button, while the board is attempting to start)- H_SKTOOC#
06-11-2025, 01:05 PM - Loading...
