Need schematic Asus G46VW Board YR-4R 1 94V-0 E114139
  • BCConnectionLLC
    • May 2015
    • 47
    Ive looked all over. Maybe someone knows where or a board schematic close to this that I can use to for diagnosis.
  • harryzanini
    • Feb 2017
    • 8
    • us
    Re: Need schematic Asus G46VW Board YR-4R 1 94V-0 E114139
    Does anyone know if there is a schematic or board diagram for the Asus Rog g46vw laptop? I have not been able to find anything. Any help would be appreciated Thanks in Advance!
    • google service center
      • Oct 2017
      • 6
      • bangladesh
        • Oct 2017
        • 6
        • bangladesh
        please
        • Flippers McCoy
          Tinkerer
          • Mar 2018
          • 106
          I, too, need this schematic
          • Flippers McCoy
            Tinkerer
            • Mar 2018
            • 106
            Actually I managed to dig something up. There's some kind of metadata in it from laptop-schematics.com which is pretty bothersome, but it works and seems to be the right thing
              • 21874
              I don`t know if this one is any good.
              • piernov
                • Jan 2016
                • 4439
                • France
                There's usually no schematics for recent Asus laptop but sometimes you can get the boardview which is of great use.
                If you really need a schematics for reference, you may use the UX31A for example. (charging circuit is often similar for example).
                The one you linked above is very old, UX31A is a bit newer. (at least it doesn't have northbridge+southbridge)
                  • 21874
                  "The one you linked above is very old, UX31A is a bit newer. (at least it doesn't have northbridge+southbridge)"
                  I didn`t look at the boar dview,just uploaded it here
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    I was talking about the schematics PDF linked above, your boardview is probably fine (I didn't take a look at it either)
                    • wilgusper
                      • Mar 2021
                      • Pitalito
                      Hello, thank you very much for the scheme, I hope to solve problem of power,
                      • alexm22
                        • Sep 2019
                        • 37
                        • argentina
                        • Clarkson green
                          • Jul 2022
                          • Cameroon
                          thanks for this sir.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • DynaxSC
                            ASUS STRIX Z490-F GAMING - No POST, stubborn board
                            by DynaxSC
                            I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                            The situation looks like this:
                            After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                            1. RTC oscillates normally (32.768KHz).
                            07-08-2022, 05:45 AM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • ShadowAi12
                            ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                            by ShadowAi12
                            I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                            • The board enters a "ready to power on" state after plugging in the PSU.
                            • Pressing the power button increases power draw.
                            • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                            Measurements:
                            (taken after pressing the power button, while the board is attempting to start)
                            • H_SKTOOC#
                            06-11-2025, 01:05 PM
