Acer 5552G, no lights, nothing. Need schematic, and some luck :(
  • inflex
    • Aug 2012
    • 544
    Client bought in an Acer 5552G, nothing showing, no power-good LED, nothing at all.
    Voltages are good at the connector on the mainboard and a couple of the nearby components. Beyond that I'm probing in the dark.
    Anyone got a schem for the 5552G series Acer?
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Acer 5552G, no lights, nothing. Need schematic, and some luck
    This ?
    • inflex
      • Aug 2012
      • 544
      Thanks for that Diif. Now comes the hard bit... fixing it.
      • inflex
        • Aug 2012
        • 544
        Okay, seems my earlier diagnosis was slightly wrong; it will power up if I put a charged battery on to it. That gives me hope ( since now I can just focus on the ACIN side )
        • inflex
          • Aug 2012
          • 544
          UPDATE #2:
          If you have both AC and battery plugged in it will NOT power up
          If you have only AC plugged in it will NOT power up
          If you have only a charged battery plugged in ( no AC ) it will start
          If you plug the AC in after it is started, it will keep running and charge the battery.
          If you remove the battery with the AC still plugged in it will keep running.
          If you connect the AC power while it is off, then connect the battery, it will not charge.
          Seems to me that something is wrong perhaps with the ACIN sense?
          • inflex
            • Aug 2012
            • 544
            UPDATE #3:
            Not sure if the problem is changing, or I'm just seeing things differently. Was able to start today with both ACIN and Battery present. Still doesn't start without the battery though.
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              with only ac in, report voltage on:
              pr61
              pq14
              pq15
              pr69 both side of resistor
              pr94 both side of resistor
              pq22
              pq56
              • inflex
                • Aug 2012
                • 544
                pr61
                pq14
                pq15
                pq22
                pq56
                PR61: 15.1V, 15.1V
                PQ14: 1~4 18.7V, 5~8 19.2V
                PQ15: 1~4 18.7V, 5~8 15.4V
                PQ22: 0.28V, 0V, 12.8V
                PQ56: 0.28V, 0V, 18.4V
                (PQ22 & 56 assuming SOT23/323 packaging pinout as pictured )
                • p1muserfan
                  • Apr 2014
                  • 184
                  Originally posted by inflex
                  PR61: 0V, 15.1V
                  PQ15: 1~4 18.7V, 5~8 8.6V
                  PQ56: 0.28V, -0.65V, 0.025V
                  Couldn't locate PR69 or 94 yet. Still searching.
                  PR69 and 94 are both located on the P2 "line" which is between PQ14 and 15. When searching for any component in a schematic with adobe reader, go to the toolbar upper left---edit---find. Type in what you're looking for, hit next, if it's found it will be highlighted for you. Works like a charm.
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    pr61 show 0v and 15volt other side ? umh looks like there must be some problem here....
                    try redo the solder both side.
                    remember only with psu and without battery.
                    edit:
                    also PQ15: 1~4 18.7V, 5~8 8.6V
                    pin 4 is 15volt ?
                    check those 2 resistor, trace them following the schematic.
                    pr94 pr69. i think problem is there.
                    if you can make a good picture of that zone (pr61 pq15)
                    to trace pr69 pr94 trace pin 4 of pq15. to enable that mosfet pin 4 must be low.
                    • inflex
                      • Aug 2012
                      • 544
                      Sorry Dellxps15, I went back and edited, I think I had a bad ground when I was measuring some of them ( should use the alligator clips! )
                      I'll take a photo of the respective areas.
                      • inflex
                        • Aug 2012
                        • 544
                        Here's a couple of images. Excuse the slightly wonky PQ14 and messy PQ15. I replaced them as "matter of standard habit" and instead of using paste+hotair reflow I got lazy and hand-soldered.
                        • dellxps15
                          • Feb 2014
                          • 1588
                          • italy
                          measure voltage in both side of each resistor pr69 pr94 as marked in picture. we cant say with one is pr69 and pr94. u have to desolder and measure with capacimeter, but firse see if they are ok (think one is dead....)
                          edit: the one upper near pq56 should be pr69 and the one down near caps 0603 should be pr94.
                          edit: see now your edit. report pu5 voltage.
                          edit3: report also voltage on pu4 pin 6
                          • inflex
                            • Aug 2012
                            • 544
                            PU5 Vdd (pin1) 0V
                            Resistors:
                            [PQ56]
                            18.7V [ ] 18.4V
                            18.7V [ ] 18.7V
                            • inflex
                              • Aug 2012
                              • 544
                              PU4[6] is 15.0V
                              PU4[5] is 3.27V
                              • dellxps15
                                • Feb 2014
                                • 1588
                                • italy
                                voltage on pl3 and pl4 ?
                                are u measuring with psu only ? rtc battery is ok ?
                                • inflex
                                  • Aug 2012
                                  • 544
                                  I think I may have found something, purely by accident... look at the 1206 ceramic between PQ5 and PQ7, looks like it's had a bad day.
                                  • inflex
                                    • Aug 2012
                                    • 544
                                    PSU only. RTC reads 2.75V
                                    • dellxps15
                                      • Feb 2014
                                      • 1588
                                      • italy
                                      it should be pc31 in schematic. try resolder it.
                                      report pl3 and pl4 voltage. if 5v and 3.3 volt pc shoult start fine.
                                      • inflex
                                        • Aug 2012
                                        • 544
                                        !!!BINGO!!! We have a winner.
                                        I don't have any 10uF 1206 25V units on hand (highest I have is 16V), but a quick test with a 2u2 item was able to make the unit start.
                                        I'll order some 25V units tomorrow.
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF314-43-R82L + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF314-43-R82L + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-43-R82L + Pack Gold Acer 14'' boardview and SF314-43-R82L + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
