MacBook Pro A2991 820-02917
  • andrikv
    • Jun 2025
    • Russia
    Hello! I'm looking for schematics (Boardview & Schematic) for MacBook Pro a2991 820-02917-05. Does anyone have it? Thanks in advance
  • Tms666
    Tech
    • Nov 2021
    Bump. I need this too
    • szape
      MacBook Pro M3 16 / Model A2991 / Board 820-02935 no LCD backlight
      by szape
      Hi!
      I have a Macbook Pro M3 A2991 which has no LCD backlight. Everything else works. Removed bottom plate, it is in immaculate condition, was not disassembled before.
      I've only made 2 measurements so far when macbook is turned on (i was in a hurry):
      PPVOUT_LUXE_XW at CP830 is 0.086V when backlight flex is connected
      PPVOUT_LUXE_XW at CP830 is 0.086V when backlight flex is disconnected
      Please help me how should i continue.
      Thank you!
      07-21-2026, 05:04 AM
    • Boardview and Schematic Bot
      Apple MacBook Pro 13 M1 820-02020-A 820-02020 Boardview and Schematic
      Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
      Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
      Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
      Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...
      06-20-2026, 10:11 AM
    • montabannour
      PD controller A2991 MacBook Pro M3 Pro 16'' Stuck at 5v 0 Amp
      by montabannour
      I would like to ask for some help for my MacBook Pro M3 pro A2991: to be honest I have limited knowledge on repairing MacBooks, this Laptop has a liquid damage but still powers on only when plugged in charger (the 2 USB Cs on the left side and the macsafe but the right USB was completely dead 5v ) and the damage was limited on the charging circuit and near the right side USB C and the Touch ID , so I cleaned it with iso Alcohol but after that he just started working fine for some minutes and detected the battery and charges it actually then this weird behavior comes on :
      all the USB ports...
      03-28-2026, 07:59 PM
    • silver60618
      Macbook M3 A2991 Speaker Audio Amplifier IC
      by silver60618
      Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
      I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
      09-26-2025, 12:25 PM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
