DELL SOUTHPEAK 15 ADL MLK 3RD MB 8L 213179-1 7X5T8$LA
  • iizik
    • Aug 2022
    • 14
    • Israel
    Flooded, water got into the screen, its connector and cable burned out, the fuse burned out (changed) but there is no screen backlight, a couple of resistors rotted. Looking for a diagram or board
  • munir100
    • Dec 2018
    • 188
    • uae
    HI i have dell 5530 problem dell log came and restar hara is bios file can any one fix for me ST 7S4JBS3 15 ADL MLK 3RD MB 8L 213179-1 7X5T8$LA
      • 22127
      Laptop bios requests go here -> https://www.badcaps.net/forum/troubl...-requests-only
      Laptop schematic requests go here -> https://www.badcaps.net/forum/troubl...-requests-only
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
      • dell_sadness
        Dell Latitude 3440 - Service tag ending in 0001 - Locked!
        by dell_sadness
        BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
        Have extracted the BIN and want to know how to rebuild a clean BIOS
        I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
        I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
        Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
        11-12-2025, 02:54 PM
