DELL SOUTHPEAK 15 ADL MLK 3RD MB 8L 213179-1 7X5T8$LA
  • iizik
    • Aug 2022
    • 14
    • Israel
    Flooded, water got into the screen, its connector and cable burned out, the fuse burned out (changed) but there is no screen backlight, a couple of resistors rotted. Looking for a diagram or board
  • munir100
    • Dec 2018
    • 185
    • uae
    HI i have dell 5530 problem dell log came and restar hara is bios file can any one fix for me ST 7S4JBS3 15 ADL MLK 3RD MB 8L 213179-1 7X5T8$LA
      • 21579
      Laptop bios requests go here -> https://www.badcaps.net/forum/troubl...-requests-only
      Laptop schematic requests go here -> https://www.badcaps.net/forum/troubl...-requests-only
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • F R 2568
        Dell Latitude 5420 does not start (no post) need help to find the reason why
        by F R 2568
        Hello all,
        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
        If the laptop is only connected to the AC adapter (battery removed):
        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
        The power/battery...
        01-08-2025, 05:45 AM
      • diamon
        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
        by diamon
        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
        Pictures of these boards:
        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
        Dell...
        02-28-2024, 12:51 PM
