Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you
					nm-f251 Schematic, boardview or help identify componente
Hello.
Boardview recently appeared on some paid sites
Unfortunately, I don't have enough points to download and share.
I would appreciate if someone shared it.Comment
Lenovo Legion Pro 5 16ARX8_LCFC_KY585_KY586_KY587_KY588_NM_F251
Drag and drope in BoardViewer 2.1.0.8Comment
Hello I’m new to the forum I tried the schematic above and it appears different than my board it’s a 16arx8 motheboard 5B21L49174. Does anyone have a schematic for that. I would greatly appreciate it appreciate thanks!
the particular component I’m trying to identify if attached and circled
This looks like what you're looking for.
ps You probably need to use the "View - Mirror Board" menu item, then the board will look the same.
Thank you so much! I rotated like you said and now I can see the components align with what I'm seeing as well as your picture. I really appreciate it have a great day 😊Comment
So I replaced the bad cap
but still no boot could anyone help point me in a direction in terms of diagnostics?
thanks 😀Comment
			by OnRepair1Hi i have been looking at a wheel from thrustmaster T300 there is a componente that its burn out and its impossible to read the code on in
The componente is the Q17 (Next to the fuse FB34) it seems that its starts with a 2 but nothing else i can see.
Does someone know or have the schematics of it?
			by pronesterHi guys,
I need some help to identify this burnt components of the GPU as per attachment.
FYI this is the GPU spec:
https://www.techpowerup.com/gpu-spec...cu-ii-oc.b2130
I have the boardview but it does not provide the parts number etc.
Does anyone have any info on this part of the circuit?
Many thanks.1 Photo-
I have problem with my graphic card GV-N3060GAMING OC-12GD.
2 smd elements are missing.
I've already bought a boardview but it's not complete - that specific area is not attached. I tried with different similar models but without success.
This is my PCB
And this is screen of boardview
As you see those missing capacitors or resistors are not on boardview.
Also i compared every single transistor from boardview to real card and everything is related.
It seems that this one is like extra.
Could anyone...-
08-09-2025, 10:26 AM -
			by AlexWhatAcer Aspire 5 A514 LA-M213P REV1.0 BoardView...
							Channel: Schematics and Boardviews
10-05-2025, 05:02 PM -
			by m1ch43lzmFor anyone who needs it, didn't find this one in the forum
6050A3348203-MB-A01
Open with FlexBV
https://www.badcaps.net/forum/troubl...acos-and-linux...-
							Channel: Schematic Requests ONLY!
09-21-2025, 11:49 PM -
 - Loading...
