Elitebook 735 G5 Bios Password
  • medinfo
    • May 2016
    • 331
    • Morocco
    HP Elitebook 735 G5 Bios Password
  • peste
    • Dec 2016
    • 13436
    • ROMANIA
    Re: Elitebook 735 G5 Bios Password
    use RCUnlocker
    • medinfo
      • May 2016
      • 331
      • Morocco
      I tested RC unlocker and HP Unlocker, still password
      • medinfo
        • May 2016
        • 331
        • Morocco
        Any other solution ?
          • 21690
          is there a 2nd chip ,16MB ?
          • medinfo
            • May 2016
            • 331
            • Morocco
            Yes
            • medinfo
              • May 2016
              • 331
              • Morocco
              i founf it now in the back
              • medinfo
                • May 2016
                • 331
                • Morocco
                unlocked thanks you
                • zak009
                  • Aug 2015
                  • 13
                  • maroc
                  Re: HP BIOS unlock tool
                  Hello, I have HP Elitebook 735 g5 this is dump from the laptop I want to fix it any help
                  • jonyhdtv
                    • Mar 2021
                    • 18
                    HP Elitebook 735 G5 (with AMD CPU) Bios Password
                    S/N: 5CG90805PH
                    Board model number: CEK92B1009Y / REV: 1.10
                    In attachment BIOS dump:
                    W25Q128JV - 16MB
                    I checked RCUnlocker - does not remove the password and HP Unlocker does not remove the password
                  • stevenmierow
                    • Jul 2022
                    I was running updates earlier on my HP Elitebook 735 G5, they included a bios update and a biometic update, and when it restarted to finish installing the updates my fingerprints and pin no longer worked on the Power On Authentication screen. I just ordered a CH341A with the SOIC8 clip and have never done this before. I want to make sure I've identified the right chips to flash and have seen you've dealt with this model before. Are the chips in the pics attached the correct ones?
                    HP Elitebook 735 G5
                    Product ID# 4HZ62UT#ABA
                    SN# 5CG903803Q
                    Motherboard L13665-601
                    Thank you so much for any input.
                    Click image for larger versionName:	Screenshot_20240118_143305_Gallery.jpgViews:	0Size:	1.25 MBID:	3181391 Click image for larger versionName:	20240118_141239.jpgViews:	0Size:	2.08 MBID:	3181392 Click image for larger versionName:	20240118_141138.jpgViews:	0Size:	2.00 MBID:	3181393
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12276
                      HP Elitebook 735 G5
                      SN# 5CG903803Q
                      25Q128JVPQ
                      • stevenmierow
                        • Jul 2022
                        I'm completely new to this and have a few questions. Is 25Q128JVPQ just where the Power On Password is stored? After reading other posts and information, I was under the impression that there were 2 chips that needed to be flashed. If so, I was trying to verify which 2 they would be, as they both appear to be BIOS related chips.
                        • Oliver144
                          • May 2024
                          • Deutschland
                          HP Elitebook 735 G5
                          I read the BIOS chip on the back and removed the menu administrator password. In my case it was an ISSI "IC25LP128" , on the front there are also two chips but I don't need to change them. I used an CH341A Programmer.
                          • MtapeK
                            • Sep 2020
                            • 38
                            • Zimbabwe
                            HP EliteBook 735 G5 No Display
                            SN: 5CG9351LD8
                            Prod ID 2HB39AV
                            The Computer seems to have a Bios Corruption Can i have help in trying to solve the issue....
                            it is Flickering the Caps Lock when switch is pressed, Also the Charger Light is flickering orange/White light interchangeably, and there will be no display.
                            i tried 3 Good known Rams there was no change
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12276
                              SN: 5CG9351LD8
                              Prod ID 2HB39AV
                              You selected the wrong chip. Chọn chip có số 128, Ex : W25Q128...
                              • MtapeK
                                • Sep 2020
                                • 38
                                • Zimbabwe
                                there you go I TOOK FROM THE ONE AT BACK NOW
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12276
                                  Not this chip, this is the EC chip, there is another chip.
                                  • MtapeK
                                    • Sep 2020
                                    • 38
                                    • Zimbabwe
                                    THIS IC NOW THE THIRD DUMP
                                    • danito
                                      • Jun 2016
                                      • 1070
                                      • Romania
                                      do it yourself:
                                      https://www.badcaps.net/forum/troubl...locker?t=98539
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • tlindi
                                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                        by tlindi
                                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                        Ack
                                        Ack
                                        01-30-2025, 04:26 AM
                                      • Nopslide
                                        by Nopslide
                                        04-01-2024, 04:27 PM
                                      • Wutru
                                        HP Elitebook 820 G4 BIOS repair assistance required
                                        by Wutru
                                        Hi guys,
                                        If someone would be able to provide some expertise, I'd be very grateful.
                                        BIOS Corruption - Cause
                                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                        09-06-2025, 10:32 AM
