HP ProBook x360 11 G1 EE - need bios password removal
  • sebbon
    • Oct 2022
    • Poland
    Hello friends.
    My mom bought a laptop with a password protected bios, could someone help me remove the password?
    The BIOS chip is a 1.8v W25Q64FWZPIQ (winbond)
    Dump is attached but i'm not sure if its correct because chip says its 64mb chip and dump has only 8mb.
    I would really appreciate any help , thanks.
  • volinakis
    • Jan 2021
    • 3255
    • N/A
    Re: HP ProBook x360 11 G1 EE - need bios password removal
    try this one
    https://www.badcaps.net/forum/showpo...1&postcount=26
    next time search for similar topics (x360 11 G1 EE) and post your request there.
    https://www.badcaps.net/forum/showth...=x360+11+G1+EE
    please support this forum
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Boot into Windows, use biosconfigutility to read config. Flash clean bios. Boot into Windows, use biosconfigutility to write config. Done.
      • miansh621
        Banned
        • May 2022
        • 133
        • pakistan
        Hp cromebook 360 11 g1 ee
        Remove enrollment
        • miansh621
          Banned
          • May 2022
          • 133
          • pakistan
          Re: Hp cromebook 360 11 g1 ee
          Originally posted by miansh621
          Remove enrollment
          help plz
          • adam536
            • May 2023
            • Poland
            Hi, I have an HP ProBook x360 G1 EE 11 laptop with a BIOS password. I can't connect a USB drive because it seems that the "latency disabled" option is set in the BIOS. When I enter the boot option, I only see IPV4 and IPV6. Is there any way to remove this password?
            Hello, I own an HP ProBook x360 G1 EE 11 laptop, which has a BIOS password. I am unable to connect a pendrive due to the apparent "latency disabled" setting in the BIOS. When I access the boot options, I only see IPV4 and IPV6. Is there any way to remove such a password?
            • spider300
              • Apr 2022
              • 35
              • morocoo
              Flash this, try to switch to devmode (you probably cant but that doesnt matter). Let it restart normally after that. You should be able to log in now. After logging in, do powerwash. After powerwash, it should be unenrolled and with dev mode unlocked.
              • ayzad
                • Aug 2025
                • pakistan
                Please help
                • Olegst44
                  Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
                  by Olegst44
                  I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
                  Device Information:
                  - Model: Acer Aspire 3 A315-22G
                  - Motherboard: NB8607G02-MB (Compal LA-J761P)
                  - BIOS Chip: Winbond W25Q64 (8MB)
                  - Serial: NXHE7ER00X95002B784S00
                  Problem:
                  - BIOS is password protected (Supervisor Password)
                  - Boot from USB is disabled in BIOS
                  - After 3 wrong password attempts, system shows Unlock Key Hint
                  - I have RT809H programmer available
                  What I need:
                  1. Clean BIOS dump (password...
                  04-11-2026, 05:36 PM
                • TopPop
                  Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                  by TopPop
                  Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                  I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                  12-14-2025, 09:40 PM
                • boticario
                  Lenovo FT491/FX390 (NM-B891 REV 2.0) – BIOS password removal/clean request
                  by boticario
                  I have a Lenovo FT491/FX390 (motherboard NM-B891 REV 2.0) with a BIOS password that I can’t bypass. I’ve tried the usual methods (CMOS reset, jumper, etc.), but the password persists.
                  What I need:
                  • A clean BIOS dump (without password) for this specific model.
                  • Or, if possible, help to remove the password from my current BIOS dump.
                  What I can provide:
                  • A full BIOS dump (W25Q80dv or similar) if someone can guide me on how to extract it safely with an RT809HSE.
                  • Any additional info or photos of the board if needed.
                  I know the community has tools...
                  03-07-2026, 10:40 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • rbdealmeida
                  Unlock Request: HP Elite Mini 8 G1a (Product B02PXAV) - BIOS Password Removal / Clean ME
                  by rbdealmeida
                  My name is Ricky and I'm a repair technician/enthusiast. I've been learning a lot from this community and have successfully done some basic BIOS unlocks in the past, but this particular modern HP model is giving me a really hard time!
                  I need some help manually removing the BIOS administrator password from this machine.
                  I have already tried using the "HP G9 Unlocker V3.0" on my 32MB dump. I successfully bypassed the U68 Sure Start chip (SPI NAND) by isolating Pin 8, preventing the auto-recovery. The machine boots and bypasses Sure Start,...
                  03-24-2026, 01:45 PM
