bricked S145-15API Bios
  • ITFan
    • Sep 2021
    • 68
    Hello dear bios experts,
    I had with a Lenovo laptop
    S145-15API
    Model name: 81UT
    S/N: PF26PMS0
    MTM: 81UT0047GE
    Factory ID: JVHFC1
    ran updates that included a firmware/bios update.
    All updates were executed and during the bios update, the system reacted strangely and started again and again with the message System updates are being executed. Last but not least was just a black screen with the power button flashing.
    I assume that the bios update failed, no boot anymore.
    I have read out the BIOS chip with a CH341A and NeoProgrammer and wanted to ask how to proceed to not make things worse.
    Gladly I send the read out Biosfile, which looks shot up in the upper part.
    Is it necessary to integrate the SN and other things in a new file? Have unfortunately of this fascinating topic very little Knowledge and would be very very glad and grateful for any help (possibly reprogrammed bios file?).
    Many greetings to all
    ITFan
  • hoaca388
    Badcaps
    • Jan 2022
    • 12347
    Re: bricked S145-15API Bios
    S145-15API
    Model name: 81UT
    S/N: PF26PMS0
    MTM: 81UT0047GE
    Factory ID: JVHFC1
    ITFan
    When you ask these questions, you should attach the corrupted bio file, someone will fix it for you, integrating the device's DMI information is necessary so posting the original bios (even though it is broken) is always request.
    • ITFan
      • Sep 2021
      • 68
      Thank you very much for the quick reply.
      Attached is the file you requested.
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        Here's your new bios file, it's a virgin bios from Lenovo with your DMI.
        all donations are welcome,
        • ITFan
          • Sep 2021
          • 68
          Oh that was very quick, thanks a lot.
          Now i have to read in in Neoprgrammer ,
          erase the chip and write the new file?
          • ITFan
            • Sep 2021
            • 68
            What kind of number is that in file (BUCN33WW)?
            It doesnt stay on Backcover.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12347
              Erase chip -> Blank check -> write -> Verify.
              • hardware1
                • Sep 2021
                • 2948
                • N/A
                It's a name or title by Lenovo refers to the bios version.
                • ITFan
                  • Sep 2021
                  • 68
                  thanks a lot, i try now
                  • ITFan
                    • Sep 2021
                    • 68
                    Oh my god, wonderful...it's booting again!
                    Top done hardware1, many thanks for your help and time.
                    How can I synchronize such a file or insert the DMI data in a new Bios file?
                    Very interesting topic!
                    I compared both files with Beyond Compare but I don't understand the differences I see.
                    • hardware1
                      • Sep 2021
                      • 2948
                      • N/A
                      Download the file from the official website, extract the .FD or .CAP file using InnoExtractor Tool, compare the 2 files and remove the extra data then your DMI should be starting from 0h to 3000h.
                      • ITFan
                        • Sep 2021
                        • 68
                        Hi again,
                        could you tell from my old bios file if the no longer booting bios was defective?
                        With what tool best compare the 2 files because of the Offset specification?
                        Many grateful greetings
                        • hardware1
                          • Sep 2021
                          • 2948
                          • N/A
                          Hi again,
                          My little knowledge doesn't help me understand if your dump file was defective or not, otherwise I'm always building a new file to be precise.
                          You can use any hex editor like (HxD).
                          • bilen
                            • Aug 2014
                            • 637
                            • istanbul
                            need S145-15API bios dump
                            motherboard code : GS440&GS540 NMC551
                            no bios chip. please lenovo sites clean bios dump..
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12347
                              Re: need S145-15API bios dump
                              This is a virgin bios , of cause it has no your dmi info.
                              • fanchiotti
                                • Feb 2023
                                • 8
                                • Brasil
                                hello, i can't make a new post as I'm a new user. I have the same problem as you and same model and make.
                                I bricked my laptop after a bios update.
                                I have the cap file, trimmed and all after using this tutorial: https://www.badcaps.net/forum/showth...pi#post1175475
                                i dont have a CH341A yet, but i'm willing to buy one and learn to tinker with it.
                                I tried to follow this tutorial: https://gbtechtips.blogspot.com/2020...r-bios-do.html but i can't extract the bios using innoextract. i get this error: "Could not open file "Bios.exe"
                                Done with 1 error." I'm in the right directory, the filename is correct and i've run it as admin. I've tried using two versions 1.9 and 1.8 and the same BUCN33WW bios version i got from lenovo's website.
                                is there any way i could get the BUCN33WW bios extracted to the fd format, so that i could follow that tutorial? would it work?
                                could someone help me, please? im desperate
                                • Mistyc
                                  • Sep 2022
                                  • 9
                                  • Italia
                                  bios lenovo s145-15api
                                  hi, my lenovo ideapad s145-15API notebook stopped working following an update. I tried to flash the bios with a bios found on the site but to no avail. I am attaching mine which I believe is corrupt. i hope you can help me.
                                  the motherboard is GS440&GS540 rev1.0 2019
                                  Thank you
                                  • hardware1
                                    • Sep 2021
                                    • 2948
                                    • N/A
                                    Re: bios lenovo s145-15api
                                    Thank you
                                    Have you tried this BIOS?
                                    https://www.badcaps.net/forum/showpo...99&postcount=4
                                    • Mistyc
                                      • Sep 2022
                                      • 9
                                      • Italia
                                      I already tried it but to no avail
                                        • 21998
                                        post the laptop serial number
                                        • akwky
                                          by akwky
                                          Hi!
                                          04-14-2025, 01:56 PM
                                        • trix11
                                          Dell Precision T1650 MT Workstation bricked after BIOS update
                                          by trix11
                                          I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                          - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                          - Dell Precision T1650 mid tower Workstation
                                          - Xeon E3-1225 V2
                                          - 32Gb PC3-12800E RAM
                                          - 4Tb SATA HDD
                                          - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                          I see now that others have experienced like issues e.g.:
                                          - https://www.dell.com/community/Prec...
                                          10-24-2022, 10:35 PM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • lordgeny
                                          z490-f gaming bricked after bios update
                                          by lordgeny
                                          I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
                                          11-02-2023, 09:03 AM
