DELL XPS 9360 BIOS Corrupted
  • sect-sin
    • May 2022
    • 103
    • Hungary
    I have a Dell XPS 13 9360 Notebook (CAZ70 LS-F051P REV 1.0(A00), symptoms are it turns on, LED's are lighting up, there is CPU FAN spin, CPU is heating up, but no POST, no display.
    Voltage is present on all rails, there are no shorts, so I think it is a BIOS issue. I have attached my BIOS dump. Could someone please send me a fixed/clean version with ME info transferred?
    I thank you very much in advance.
    Cheers,
    sect-sin
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: DELL XPS 9360 BIOS Corrupted
    Dell XPS 13 9360
    • sect-sin
      • May 2022
      • 103
      • Hungary
      Originally posted by hoaca388
      Dell XPS 13 9360
      Hi hoaca,
      Thank you for the BIOS files. I used the non-vpro version, as I think the notebook is a non-vpro version (though I am not 100% sure).
      It still does not POST, but the symptoms have clearly changed. Now there is a 2 amber, 5 white error blink code, which means wrong memory installed, then there is a short fan spin, and then shutdown.
      This is strange, as the memory is soldered on the board.
      1) Should I try the vpro version?
      2) Is there something wrong with the BIOS file you gave me?
      3) Or is the soldered memory faulty?
      What do you think?
      Cheers,
      sect-sin
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        No problem with bios files, if both don't post clearly the error is not due to bios.
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Loli Popu
          DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 08:29 AM
        • capoplays
          Help with BIOS update on Dell G15 5515 after chip replacement
          by capoplays
          Hey everyone,
          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
          When I check the BIOS using the F12 menu Flash...
          10-24-2025, 06:53 AM
        • wwbielsko
          Dell latitude 5320 corrupted bios repair
          by wwbielsko
          I got corrupted bios bin file, which way is correct to repair.
          File puts errors on Me Analyzer and cannot open in FIT.
          To open in FIT I made:
          1. Extract MFS and EFS using MEAnalyzer from other bios file with the same parameters
          2. put it in HxD to my file
          3. MEAnalyzer shows 1 error after that
          4. file opens in FIT
          and:
          A:
          1. extract current dell bios on website
          2. put System BIOS with BiosGuard v1.30.0.bin using FIT
          3. MEAnalyzer OK no errors
          (this version shows only logo at bootup - freezeing)...
          04-23-2024, 06:16 PM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
