Test ok
MONSTER ABRA A7 V12.1-6-71-nh5b0-d02
The bios of the device I have has been tampered with with the 25u8035 installed in the u37. The bios is available but I am not sure about the 1mb file in the 25u8035. I am attaching the file. If anyone has it, can they share it?Attached Filesif you find these attachements useful please consider making a small donation to the site
post S/N, full name and model, motherboard model,etc.
Every donation made will go towards server fees and maintenance costs.Comment
by jaglion19GI5CNXA MB v1.0 monster Abra A5 V13.3 SR40B HM370
Good luck to everyone, my problem is as follows. I have a la-f841p rev 1a motherboard, which occasionally gives a blue screen due to the processor running the motherboard. I installed the southern chipset of this motherboard into the short-circuited device with Monster Abra A5 v13.3 GI5CNXA MB v1.0. When I trigger the monster device, it goes up to 230mah and turns it off again. I have tried many of these devices before, but I did not get any results. They definitely want a brand new chipset. Other models do not have this problem,... -
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by mhd beroHELLO EVERYONE
MONSTER ABRA A7 V13.1 HAS PROBLEM WITH NVIDIA GPU I DO REMOVE THE CHIP AND NVVDD COIL IT IS WORKING WITH INTEL GPU BUT SHUTTING DOWN AFTER ONE MINUTE CAN WE DISABLE DIS GPU FROM BIOS?
THE MOTHERBOARD CODE 6-71-NK5K0-D02A NH50HKMB-0C -
by fatihkudumonster abra a5 v15.8 gk5mp5x v1.1 bios serial no:gk5mrfv2204900539 mns201203000118
i7 10th generation
I changed the srjau. The image comes late. please clean me
late image bios added...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
