Monster Abra A7 V13.1 DIS GPU to UMA
  • mhd bero
    • Oct 2016
    • 23
    • turky
    HELLO EVERYONE
    MONSTER ABRA A7 V13.1 HAS PROBLEM WITH NVIDIA GPU I DO REMOVE THE CHIP AND NVVDD COIL IT IS WORKING WITH INTEL GPU BUT SHUTTING DOWN AFTER ONE MINUTE CAN WE DISABLE DIS GPU FROM BIOS?
    THE MOTHERBOARD CODE 6-71-NK5K0-D02A NH50HKMB-0C
  • _Margo_
    • Sep 2022
    • 7
    • Россия
    Hi. Have you solved this problem?
    • jaglion19
      GI5CNXA MB v1.0 monster Abra A5 V13.3 HM370 CHANGE
      by jaglion19
      GI5CNXA MB v1.0 monster Abra A5 V13.3 SR40B HM370
      Good luck to everyone, my problem is as follows. I have a la-f841p rev 1a motherboard, which occasionally gives a blue screen due to the processor running the motherboard. I installed the southern chipset of this motherboard into the short-circuited device with Monster Abra A5 v13.3 GI5CNXA MB v1.0. When I trigger the monster device, it goes up to 230mah and turns it off again. I have tried many of these devices before, but I did not get any results. They definitely want a brand new chipset. Other models do not have this problem,...
      04-10-2025, 06:59 AM
    • s.izadbakhsh
      Monster Abra A5 V19.3 - Tongfang GM5AGFO MB V1.1 - BIOS Dump Clean ME Request
      by s.izadbakhsh
      I need a working BIOS dump for a Monster Abra A5 V19.3 laptop.
      Here are the motherboard details:
      • Model: Tongfang GM5AGFO MB V1.1
      • CPU: Intel 12th Gen (Alder Lake)
      The laptop is currently in a boot loop (turns on and off immediately). I have desoldered the SPI Flash IC (GigaDevice GD25R256DYIG) and read the original 32MB dump.
      Note: I have already tried testing another BIOS dump found online, but the laptop behaves exactly the same (on/off boot loop) with both the original dump and the other file.
      Could someone please provide...
      06-24-2026, 09:10 AM
    • s_specialist
      Monster Abra A5 V16.7 SRKMA burned
      by s_specialist
      The south bridge (SRKMA) on my Monster Abra A5 V16.7 was burnt, causing a 1.8V short circuit to the chip. I installed a chip I bought from Aliexpress, assuming it was brand new, and the 1.8V output improved, but when I pressed the power button, it drew 0.03A and didn't start. I can measure 3.3V, 1.8V, and 1.05V on the chip. The BIOS has 3.3V on pins 1, 2, 3, and 8. When I pressed the power button, it drops to 3.3V. I get EC_RSMRST voltage from the IT5570E, but I don't have SLP_S4 and SLP-S5 voltages. I've written the bios files I could find, but I can't find anything. Is the integrated circuit...
      11-01-2025, 03:44 AM
    • fatihkudu
      monster abra a5 v15.8 gk5mp5x v1.1 bios
      by fatihkudu
      monster abra a5 v15.8 gk5mp5x v1.1 bios serial no:gk5mrfv2204900539 mns201203000118
      i7 10th generation
      I changed the srjau. The image comes late. please clean me
      late image bios added​...
      10-14-2024, 09:07 AM
    • asliyucegsm
      monster abra a7 v12.5 schema request
      by asliyucegsm
      Does anyone have the schematic or boardview for this motherboard? Thanks.
      Type the part number
      P\N:6-77-NH77HHQ0-D02A-3C#10...
      08-07-2026, 03:30 AM
