HP G6-2277ST (da0r33mb6f0 rev f) G6-2005ST (da0r33mb6f1 rev f) MAIN+EC BIOSES
  • Reisharman
    • Oct 2022
    • 11
    • Turkiye
    Hey guys. I really messed things up with those two motherboards' both main and ec bioses. I have CH341A and EZP2019+ programmers and I tried to program both EC and MAIN bios chips but capslock blinking and boards won't boot up. I found bioses for mainboard codes from google and from this forum but they didn't work. I cleaned ME it didn't worked too. Can anybody help me to revive those corpses again? Thanks you so much.
  • peste
    • Dec 2016
    • 13301
    • ROMANIA
    Re: HP G6-2277ST (da0r33mb6f0 rev f) G6-2005ST (da0r33mb6f1 rev f) MAIN+EC BIOSES
    do you have the original bios?..post them..
    • Reisharman
      • Oct 2022
      • 11
      • Turkiye
      Hey mate thanks for your reply. Here is my original bios files. But I am not sure if i save them clean by programmers. And there is another issue that I programmed those bioses then two motherboard power IC's gone short. I will be crazy
      • Reisharman
        • Oct 2022
        • 11
        • Turkiye
        I replied mate. Thank you.
        • peste
          • Dec 2016
          • 13301
          • ROMANIA
          bios extracted from HP site update..
          DMI 36F000 - 36F0FF
          KEYWIN 1CD000 - 1CD03F
          • Reisharman
            • Oct 2022
            • 11
            • Turkiye
            DMI 36F000 - 36F0FF
            Man thank you for your support. Can i use them for both mobos? I will try and reply for the result. But first I have to replace power ics.
            • Reisharman
              • Oct 2022
              • 11
              • Turkiye
              DMI 36F000 - 36F0FF
              Man i tried on both cards but it didn't work. Capslock keeps flashing. What should i do?
              • peste
                • Dec 2016
                • 13301
                • ROMANIA
                you probably didn't write them correctly... or the laptop has other problems... what initial problem did your laptop have with going to the bios?...
                • Reisharman
                  • Oct 2022
                  • 11
                  • Turkiye
                  Actually initial problem wasn't about bios. it was a wrong diagnosis and everything went wrong after that. I swapped chips on two motherboards first it worked but couldn't format clean windows because of bsod. Now I am measuring 0.2 volts on first leg of ec bios chip. Is it normal or I should read 3v3?
