Image dump fromt 2 Programmers different
  • x16
    • May 2015
    • 83
    i'am reading since 1 year my dumps with RT809F.
    Now i bought a svod4 from ebay. The svod 4 ist realy fast, but when i compare the dumps of both programmers, they are not identical.
    Anyone knows why?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Image dump fromt 2 Programmers different
    To be comparable, dumps must be taken on the same machine with no power applied at all between the 2 take.
    • reformatt
      • Feb 2020
      • 1418
      Check SPI speed is at 10.5Mhz for SVOD and not 22Mhz. Doesn't work properly on the higher speed.
      • x16
        • May 2015
        • 83
        Yes both dumps are from same machine and no power ist applied.
        OK i test it with lower SPI Speed.
        • f-bone
          Asus K513E no image, bios dump attached
          by f-bone
          Hi guys!
          I have this laptop which is turning on but has no image. I have attached the bios dump but I can't seem to find a working one. I also read a similar thread mentioning WBT.exe v314 but no instructions on how to use that.
          Can you please help me with a working binary that includes the DMI info from my dump? Or kick me to the right direction to try and add the DMI section myself? I used HxD on my dump and found the serial on multiple places so I am not sure what to copy.
          thank you very much in advance!
          br,
          george...
          07-04-2023, 02:27 AM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • CA50
          Help with file extraction from DVR firmware dump
          by CA50
          Hello experts,
          I have both dump and firmware from a DVR system. I need to extract the linux file system from the dumps.
          I tried with binwalk, but could not get all the files. Can anyone please help me with the steps.
          I have included the firmware in the attachment and here is the current binwalk output
          Code:
          DECIMAL    HEXADECIMAL   DESCRIPTION
          178176    0x2B800     CRC32 polynomial table, little endian
          188568    0x2E098     CRC32 polynomial table, little endian
          06-01-2023, 09:20 AM
