lenovo hs461&hs561&hs761 nm-d251 rev:2.0 bios bin file
  • hoaca388
    Badcaps
    • Jan 2022
    • 12338
    Originally posted by igalex796
    SN: PF40B5BT
    REBUILD 14ALC6 hs461&hhs561&hs761 NM D521 REV 3.0 21-10-26
    PLS only power led
    IdeaPad 3-14ALC6 Laptop - Type 82KT
    • zEr04
      • Nov 2025
      • 4
      After nearly a month of banging my head trying to bring the laptop back to life, I am in need of a donor bios for the model below please.
      I have a CH341a + 1.8V adapter and using both AsProgrammer and NeoProgrammer.
      Lenovo ideapad 3-14ALC6
      Motherboard
      LENOVO LNVNB161216
      Model 82KT
      serial no. PF4BLJA1
      Chip: GigaDevice
      25LR128DSIGUGT942AJ2151
      • peste
        peste commented
        Editing a comment
        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
    • peste
      • Dec 2016
      • 13653
      • ROMANIA
      Motherboard
      LENOVO LNVNB161216
      Model 82KT
      serial no. PF4BLJA1
      Chip: GigaDevice
      post the contents of the bios chip even if it is corrupted..
      post motherboard model..
      • zEr04
        • Nov 2025
        • 4
        Thank you.
        Unsure of the corrupt bios, but attached if helps.
        MB model: HS461&HS561&HS761 NM-D521
        2021-10-26 Rev 3.0
        • zEr04
          • Nov 2025
          • 4
          I've managed to use the file from Hardware1 on Page 1, so no need atm. Working now all good! You guys rock!
          • to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
            by to5it0
            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
            I have opened the laptop and identified the main BIOS chip...
            10-24-2025, 01:35 AM
          • Forest79
            by Forest79
            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
            07-23-2023, 07:39 AM
          • survivalbloke
            Unable to extract bios file from Lenovo bios exectuable
            by survivalbloke
            I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
            Code:
            "innoextract 7wcn38ww.exe"
            it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
            The trouble I'm having is that I'm not getting the newly...
            06-12-2024, 07:55 AM
          • maanee11
            Help to get Lenovo BIOS bin file for Thinkpad T560
            by maanee11
            Hello Everyone,
            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
            05-15-2022, 11:59 AM
          • survivalbloke
            Unable to extract Lenovo BIOS file from installer
            by survivalbloke
            I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
            I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
            How can...
            07-16-2025, 03:21 PM
