6-71-W2300-D03 bios file (clevo w230st)
  • vienzen
    • Feb 2015
    • 113
    • PHILIPPINES
    Hi, I need please bios BIN file
    The Main Board is: 6-71-W2300-D03
    Thanks!
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: 6-71-W2300-D03 bios file (clevo w230st)
    Thanks!
    https://repo.palkeo.com/clevo-mirror/
    username repo
    password repo
    • vienzen
      • Feb 2015
      • 113
      • PHILIPPINES
      username repo
      password repo
      thank you peste
      I downloaded the bios zip file but not a BIN file
      how to convert to bin file?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        thank you peste
        See the pictures !
        • vienzen
          • Feb 2015
          • 113
          • PHILIPPINES
          Originally posted by hoaca388
          See the pictures !
          thank you sir for the response
          the file is 6mb and the bios chip is 4mb and 2mb
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            Post original bios files.
            • vienzen
              • Feb 2015
              • 113
              • PHILIPPINES
              bios backup
              • hoaca388
                Badcaps
                • Jan 2022
                • 12441
                bios backup
                w230st
                  • 22279
                  We cann find out how the file should be split with Intel Flash Image Tool . Find the ME firmware version first using ME Analyzer,then we know which version of FIT to use to open the 6MB bios with. This has version 9 ME firmware so we use FIT from "ME System Tools v9.1 " .Open the bios with FIT,look in the Decomp folder and open "BIOS Region.bin" with a hex editor. Comparing it with your backups you should see that the bios region is the 4MB.The bios region (2nd part) is always after the 1st part.The file wants splitting into 2MB and 4MB .Close FIT ,open with a hex editor and split - https://www.badcaps.net/forum/showpo...60&postcount=4
                  Another way you can split the file is to clean the already cleaned ME firmware,after building the image it will be automatically split into 2 and 4MB.
                  HxD hex editor https://mh-nexus.de/en/downloads.php?product=HxD20
                  ME System tools https://www.badcaps.net/forum/showthread.php?t=88533
                  • hassan el fakkak
                    • May 2024
                    • Morocco
                    Hello brother, can you help me regarding the BIOS files?
                    I searched a lot for clevo w230st BIN files
                    I did not find it. I updated the BIOS and it did not work and the computer does not want to work
                    In order to fix it, I need the files I told you about
                    I found it on a site but i need to by it
                    If you have, please share it with me.
                  • to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                    by to5it0
                    Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                    I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                    This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                    I have opened the laptop and identified the main BIOS chip...
                    10-24-2025, 01:35 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • maanee11
                    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                    by maanee11
                    Hello Everyone,
                    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                    In the website, you can only see specs etc.
                    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                    11-08-2025, 04:08 AM
                  • m1ch43lzm
                    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                    by m1ch43lzm
                    Hi everyone
                    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                    There's also an extra OTP Secu.R...
                    09-06-2025, 05:47 PM
                  • princebuzz
                    BIOS REQUEST FOR CLEVO PE60RNE-G
                    by princebuzz
                    I’m looking for the correct BIOS / EC / ME firmware for a CLEVO PE60RNEQ laptop that was sold by Scan as a 3XS system. The laptop has developed a boot issue that appears to be firmware-related, and I’m hoping someone can provide a dump or the correct files.
                    System Information:
                    • Base laptop model: CLEVO PE60RNEQ (NP60RNEQ)
                    • Motherboard ID: PE60RNE_RND_RNC
                    • Vendor: Scan 3XS (UK)
                    • Unfortunately, I no longer have the original box.
                    Firmware Versions (from BIOS):
                    • BIOS Version: 1.07.07SCI
                    • EC/KBC Firmware Version: 1.07.07
                    • Intel ME Firmware Version:
                    11-29-2025, 03:09 PM
