BIOS Req: X1 Extreme
  • Savelii Hazhala
    • Jan 2025
    • 3
    Good day. Guys, help me with the BIOS.
    Laptop
    Lenovo ThinkBook X1 Extreme 1st 20MF
    S/N: R9-0SL3S2
    I need help, I can't download the original BIOS from the official site. I would be very glad to have your help. The laptop is in a constant on-off cycle, I think the problem is in the BIOS
    • hardware1
      • Sep 2021
      • 2946
      • N/A
      Laptop
      S/N: R9-0SL3S2
      This file for "ThinkPad P1 Gen 1" not "ThinkPad X1 Extreme 1st gen", also I found this serial number "R90RPKUQ"in your file and it refers to "ThinkPad P1 Gen 1".
      For your info, there is nothing called ThinkBook X1 Extreme 1st gen!
      Remember to write your motherboard number also.
      all donations are welcome,
      • Savelii Hazhala
        • Jan 2025
        • 3
        Hmmm, I'm pretty sure the laptop is "ThinkPad X1 Extreme 1st gen"
        Motherboard:
        LPM-1 MB
        17870-1
        448 . 0DY05 . 0011
        • hardware1
          • Sep 2021
          • 2946
          • N/A
          Laptop
          S/N: R9-0SL3S2
          Here is your new BIOS file, try it and let me know.
          Read your post again, you said ThinkBook not ThinkPad and it's a different series.
          Anyway, this file is compatible with both "ThinkPad X1 Extreme 1st Gen" and "ThinkPad P1 Gen 1".
          • Savelii Hazhala
            • Jan 2025
            • 3
            And yes, I saw my mistake, laptop Lenovo ThinkPad X1 Extreme gen1
            The behavior has not changed, I connect the power cable, the laptop tries to start but immediately turns off, the charging light blinks in two colors at once
            • master3112
              • Mar 2024
              • 87
              • Slovakia
              #26
              I also have a LPM-1 MB 17870-1 Lenovo X1 Extreme Gen.1 with Intel Core i5-8300H and NVIDIA GeForce GTX 1050 Ti 4GB. The device turns on and the fans spin, but there is no picture. When I remove RAMs, the device beeps that there are no RAMs. I downloaded the BIOS "X1_dump_Re.rar" from danito's post and installed it. Unfortunately, nothing has changed. Is it because it is from the other device? Does the original BIOS file from my own device need to be modified, or is the BIOS universal for all devices and I may have a different problem? In terms of hardware, I have no anomalies on the board. Thanks for your help.
              • master3112
                • Mar 2024
                • 87
                • Slovakia
                #27
                Here is the serial number of my X1 Extreme 1st Gen Type 20MF with the bios Problem.
                SN: R9-0RQBNB
                I hope someone can help me.
                  • 21682
                  How did you install the bios,and did you make a backup first
                  • master3112
                    • Mar 2024
                    • 87
                    • Slovakia
                    #29
                    I desoldered the BIOS chip, made a backup with SVOD Programmer and then programmed the BIOS chip with the BIOS file "X1_dump_Re.rar" from danito's post from the forum.I need the original BIOS File?
                      • 21682
                      Post your backup
                      • master3112
                        • Mar 2024
                        • 87
                        • Slovakia
                        #31
                        Here is the original bios from my X1 extreme.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12272
                          #32
                          X1 Extreme 1st Gen Laptop (ThinkPad) - Type 20MF
                          • master3112
                            • Mar 2024
                            • 87
                            • Slovakia
                            #33
                            Thank you hoaca388
                            Unfortunately nothing has changed. The device boots up as before, but the screen remains black. There is also no output via HDMI. I have noticed one more thing. When the device is switched on, it should be possible to press the capslock button and the light in the button should light up. The FN keys do not work either. Is this perhaps an indication of a possible fault? Or am I wrong?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12272
                              #34
                              Thank you hoaca388
                              Check hardware.
                              • SeverSem
                                • May 2018
                                • 11
                                • Russia
                                #35
                                ThinkPad x1 Extreme 20MF-000CUS s/n R9-0RN7JM Freezes without a picture. Help me find a dump please. With the rest of the dumps - the laptop does not turn on
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12272
                                  #36
                                  • PULIO1500
                                    • Aug 2022
                                    Could anyone help me with a BIOS bin file to flash my ThinkPad, which is currently password in the BIOS?
                                    thinkpad x1 extreme gen 1
                                    model : 20MF-000DUS
                                    bios : N2EET42W (1.24)
                                    s/n : R9-0V246W
                                    year : 19/05
                                    note : I already tried with Lenovo Patches v2 and it left my laptop with a black screen and beeps as if it was missing memory ram.
                                    • DynaxSC
                                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                      by DynaxSC
                                      Hi
                                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                      08-04-2025, 12:20 PM
                                      by SMDFlea
                                      Bad...
                                      09-02-2021, 04:40 PM
                                    • JoWed
                                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                      by JoWed
                                      Hello Community,
                                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                      07-01-2025, 09:32 AM
                                    • inck243
                                      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                      by inck243
                                      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                      The BIOS...
                                      07-25-2024, 09:17 AM
                                    • BMCappelletti
                                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                                      by BMCappelletti
                                      Long story short:
                                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                      - gave the computer to his son a couple years later
                                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                      (seems like the story was not that short)
                                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                      01-08-2025, 07:27 PM
