BIOS Req: X1 Extreme
  • Savelii Hazhala
    • Jan 2025
    Good day. Guys, help me with the BIOS.
    Laptop
    Lenovo ThinkBook X1 Extreme 1st 20MF
    S/N: R9-0SL3S2
    I need help, I can't download the original BIOS from the official site. I would be very glad to have your help. The laptop is in a constant on-off cycle, I think the problem is in the BIOS
    • hardware1
      • Sep 2021
      • 2898
      • N/A
      Laptop
      S/N: R9-0SL3S2
      This file for "ThinkPad P1 Gen 1" not "ThinkPad X1 Extreme 1st gen", also I found this serial number "R90RPKUQ"in your file and it refers to "ThinkPad P1 Gen 1".
      For your info, there is nothing called ThinkBook X1 Extreme 1st gen!
      Remember to write your motherboard number also.
      all donations are welcome,
      • Savelii Hazhala
        • Jan 2025
        Hmmm, I'm pretty sure the laptop is "ThinkPad X1 Extreme 1st gen"
        Motherboard:
        LPM-1 MB
        17870-1
        448 . 0DY05 . 0011
        • hardware1
          • Sep 2021
          • 2898
          • N/A
          Laptop
          S/N: R9-0SL3S2
          Here is your new BIOS file, try it and let me know.
          Read your post again, you said ThinkBook not ThinkPad and it's a different series.
          Anyway, this file is compatible with both "ThinkPad X1 Extreme 1st Gen" and "ThinkPad P1 Gen 1".
          • Savelii Hazhala
            • Jan 2025
            And yes, I saw my mistake, laptop Lenovo ThinkPad X1 Extreme gen1
            The behavior has not changed, I connect the power cable, the laptop tries to start but immediately turns off, the charging light blinks in two colors at once
            • master3112
              • Mar 2024
              • 67
              • Slowakei
              #26
              I also have a LPM-1 MB 17870-1 Lenovo X1 Extreme Gen.1 with Intel Core i5-8300H and NVIDIA GeForce GTX 1050 Ti 4GB. The device turns on and the fans spin, but there is no picture. When I remove RAMs, the device beeps that there are no RAMs. I downloaded the BIOS "X1_dump_Re.rar" from danito's post and installed it. Unfortunately, nothing has changed. Is it because it is from the other device? Does the original BIOS file from my own device need to be modified, or is the BIOS universal for all devices and I may have a different problem? In terms of hardware, I have no anomalies on the board. Thanks for your help.
              • master3112
                • Mar 2024
                • 67
                • Slowakei
                #27
                Here is the serial number of my X1 Extreme 1st Gen Type 20MF with the bios Problem.
                SN: R9-0RQBNB
                I hope someone can help me.
                  • 20318
                  How did you install the bios,and did you make a backup first
                  • master3112
                    • Mar 2024
                    • 67
                    • Slowakei
                    #29
                    I desoldered the BIOS chip, made a backup with SVOD Programmer and then programmed the BIOS chip with the BIOS file "X1_dump_Re.rar" from danito's post from the forum.I need the original BIOS File?
                      • 20318
                      Post your backup
                      • master3112
                        • Mar 2024
                        • 67
                        • Slowakei
                        #31
                        Here is the original bios from my X1 extreme.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11213
                          • Viet Nam
                          #32
                          X1 Extreme 1st Gen Laptop (ThinkPad) - Type 20MF
                          • master3112
                            • Mar 2024
                            • 67
                            • Slowakei
                            #33
                            Thank you hoaca388
                            Unfortunately nothing has changed. The device boots up as before, but the screen remains black. There is also no output via HDMI. I have noticed one more thing. When the device is switched on, it should be possible to press the capslock button and the light in the button should light up. The FN keys do not work either. Is this perhaps an indication of a possible fault? Or am I wrong?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11213
                              • Viet Nam
                              #34
                              Thank you hoaca388
                              Check hardware.
                                Common SPI bios chip programming Questions and Answers
                                by SMDFlea
                                Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                A: If you can`t read from it how do you expect to write to it ?.
                                Q: Why is my bios chip unreadable ?.
                                A: The programmer is faulty or has a worn or broken zif socket.
                                The USB cable is frayed,connector pins worn or some other physical damage.
                                Not enough amperage or voltage to power the programmer properly.
                                Bad...
                                09-02-2021, 04:40 PM
                              • inck243
                                Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                by inck243
                                Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                The BIOS...
                                07-25-2024, 09:17 AM
                              • BMCappelletti
                                Asus Chromebox CN62 - wrong chip put on BIOS reader
                                by BMCappelletti
                                Long story short:
                                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                - gave the computer to his son a couple years later
                                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                (seems like the story was not that short)
                                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                01-08-2025, 07:27 PM
                              • thxd43
                                Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                by thxd43
                                Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                I have a Lenovo ideapad 330S - 14IKB laptop.
                                The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                02-23-2023, 08:37 PM
                              • h3ct0r
                                T15g Bricked BIOS - Which chip has the BIOS?
                                by h3ct0r
                                Hello, after what is seems like a bad BIOS firmware upgrade, the machine had extrange visual glitches and froze.
                                The laptop now does not turn on as normal, and does not make post or show the BIOS page: It will stay at a blank page with beeping sounds: https://youtu.be/OC2o9_b1RQ0
                                I'm planning to flash the bios chip with a CH341A, but it seems that they are three chip candidates:
                                1. Winbond 25Q80DVSIG (3V 8M-bit) Located on the GPU board
                                2. MXIC 25U8035F (1.8V 8M-bit) Located on the GPU board
                                3. Winbond 25Q80DVNIG (3V 8M-bit) Located on the CPU board
                                4. Winbond W25Q256JV (3V 256M-bit)
                                10-11-2024, 08:35 PM
