need bios Dell Latitude 9420 LA-K161P
  • cgtec
    • Feb 2014
    • 56
    • France
    need bios for dell 9420 svt: 4NLZ3M3
    CPU I5 11TH
    RAM-16GB
  • hardware1
    • Sep 2021
    • 2940
    • N/A
    Re: need bios Dell Latitude 9420 LA-K161P
    CPU I5 11TH
    RAM-16GB
    Upload your original bios file.
    all donations are welcome,
    • cgtec
      • Feb 2014
      • 56
      • France
      orginal bios is crupted .
      i try to clear me and repare not work
      • hardware1
        • Sep 2021
        • 2940
        • N/A
        Here's your new bios file, try it and let me know the results.
        • cgtec
          • Feb 2014
          • 56
          • France
          no power nothig not work
          • hoaca388
            Badcaps
            • Jan 2022
            • 11891
            Latitude 9420
            Service Tag: 4NLZ3M3
            • cgtec
              • Feb 2014
              • 56
              • France
              Originally posted by hoaca388
              Latitude 9420
              same think no power
              itry another dump ffrom laptop 9420 i7 11th ..
              laptop is power on . show logo but stil logo loop restar and somtime screen RVB bleu red green balck and restar
              • cgtec
                • Feb 2014
                • 56
                • France
                https://www.badcaps.net/forum/showth...highlight=9420
                • hardware1
                  • Sep 2021
                  • 2940
                  • N/A
                  Try this one.
                  • cgtec
                    • Feb 2014
                    • 56
                    • France
                    Try this one.
                    not work same problem
                    • lapfix
                      • Mar 2020
                      • 2742
                      • my workshop
                      My friend , there's a difference between not working and work but stuck at logo dell , you must precise the information given .
                      One question : did you change the bios chip ! it must be GigaDevice GD25x256C
                      • cgtec
                        • Feb 2014
                        • 56
                        • France
                        stuck at logo dell
                        i change chip to winbond 25q256
                        • lapfix
                          • Mar 2020
                          • 2742
                          • my workshop
                          At your VSCC table there's only GigaDevice GD25x256C , no winbond ; so i suggest to back up the old chip
                          • cgtec
                            • Feb 2014
                            • 56
                            • France
                            i use gd25x256c stuk on logo
                            • cgtec
                              • Feb 2014
                              • 56
                              • France
                              the orginal chip is XM25RH256C ...
                              • cgtec
                                • Feb 2014
                                • 56
                                • France
                                i try w25R256jv not work try xm25QH256b not work
                                • lapfix
                                  • Mar 2020
                                  • 2742
                                  • my workshop
                                  Try this new build from the stuck logo
                                  • trunguntilyou
                                    • Aug 2022
                                    • 330
                                    • Vietnam
                                    Latitude 9420
                                    LA-K161P REV:1.0
                                    Service Tag: 532T0J3
                                    Machine condition: the machine has a camera shield switch, but it cannot be turned on or off, you can only hold the off button still and the camera will be shielded,,, and release the button, the camera is no longer shielded,, the whole assembly has been replaced The other screen is still the same, Windows is installed
                                      • 21186
                                      Originally posted by trunguntilyou
                                      Latitude 9420
                                      LA-K161P REV:1.0
                                      Do you have the correct drivers installed. Latitude 9420 Internal Camera Not Detected or Not Working https://www.dell.com/support/kbdoc/e...not-functional
                                      • trunguntilyou
                                        • Aug 2022
                                        • 330
                                        • Vietnam
                                        I've tried everything, and the only way to control the camera cover is to turn it on and off. It's controlled by the F9 button. If you hold down the F9 button, it blocks the camera. If you release it, it turns on the cover. It's not on or off. 1 click, not the camera driver, the camera still works
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                          DELL Latitude 9420 Notebook 9000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 9420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9420 boardview and 9420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 9420...
                                          09-07-2024, 03:40 AM
                                          DELL Latitude 9420 2in1 Hybrid (2-in-1) 9000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 9420 2in1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9420 2in1 boardview and 9420 2in1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
