Bios unlock for DELL LATITUDE 7420
    Originally posted by Mani26 View Post
    Hi, I appreciate if someone can help with unlocking the Bios admin password for Dell Latitude 7420. Details as follows.
    82KS2J3-8FC8
    Service Tag: 82KS2J3
    BIOS Version: 1.21.0
    Express Service Code: 17570093007
    Please let me know if any other details are required. Thanks
    where is the bios dump?
      This is a after market device. Old user credentials were not flushed. So, I am unable to bypass. Is there anyway to get bios dump?
        you need bios programmer like cheap ch341a and hot air and do some research in youtube university.
          I'm desparate, I don't have a dump because i've wrong the model of flash. I've readed it like a W25Q256 but the label of mine is a 25R256JVEN and it was happened when i've tried to post here.
          Someone can help me, please? I need a new bios without password.
          Here my info:
          LATITUDE 7420
          service tag: 6Q7C0F3
          Bios Version: 1.23.1
          motherboard model: GDC31 LA-K371P Rev. 3.0 (A02) 2021-01-21.
          PWB PN: D955X
          spi model: Winbond 25R256JVEN
          Thank you
            Here my info:
            LATITUDE 7420
            PWB PN: D955X
            Thank you
            So you have image only issue is bios locked
            you just read bios with any name that is not an issue file size should be same just verfy your dump in hxd and post here
              I've tried many times and now the flash is unreadable. I think is broken. Infact i've bought new flashes.
              I've the first dump but i've read with a wrong model setting and could be results corrupted.
              Below the dump, if i remember well it is the first reading with the wrong flash setting. Then my programmer doesn't recognize the pins and the dump was formed only by FF values. How you can see the name of file includes the wrong setting W25Q256 instead 25R256.
              Can we try with it, please? Thank you.
                you can try this its a tested bios if no luck than we will chk your posted bios
                  Nothing, i,ve flashed but the fan runs in high RPM and the screen is black. I've used a new flash and i've programmed with tl866II Plus with auto-detect chip setting.
                    use this.
                    1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
                      Originally posted by rex98 View Post
                      use this.
                      Great, great, great!!
                      Thank you very much, the laptop now works!!!
                        Hi !
                        Anybody help me to remove bios password Dell latitude 7420
                        ST: 5SYZ0F3 - 8CF8
                        32Mb bios file attached.
                        Thanks in advance
                          Originally posted by vuiquata007 View Post
                          Hi !
                          ST: 5SYZ0F3 - 8CF8
                          Thanks in advance
                          Send to you
                            Originally posted by minhdigital View Post
                            Send to you
                            It's work perfect. Thank you Minh đại ca
                              I have dell 7420 was locked but during reading BIOS looks not succeed because when i return its original just changing colour but this is one work perfectly with BIOS password am getting confused for sure
                              Help me to unlock and clean me please may will help me as botelo
                              motherboard number LA-K371P
                              SERVICE TAG: 6ZGQ5D3
                                Latitude 7420
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  Thank you so much for reply but just hanging on logo am hopeless now
                                  any one help me with working file
                                    Try older version
                                      help pls remove computrace lock!
                                      I'm sorry if I'm not allowed to request 2 bios at the same time
                                      st: 47QBCK3 and DML1FK3
                                        VVVV
                                          Originally posted by hoaca388 View Post
                                          VVVV
                                          works perfect! Thank you, comrade, I tried comparing with HDX to try it myself but I saw a lot of change, it's difficult to do it myself.
