Need Bios Dump Alienware 17 P31E
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    Need bios dump for Alienware 17 P31E
    code board DDR51 LA-F551P Rev. 1.0
    thanks alot
    Original backup file, no display
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    Re: Need Bios Dump Alienware 17 P31E
    flash bios with this file, can display but can't enter os
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      Try this new file and give me the results.
      You Service tag is: B3Y6VP2
      all donations are welcome,
      • cyngo
        • Jun 2015
        • 219
        • Indonesia
        not working bro, laptop become dead
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • TechMark1
          Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
          by TechMark1
          I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
          09-21-2025, 03:36 PM
        • drux
          Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
          by drux
          I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
          Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
          These models have AMI/Aptio BIOS.
          Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
          11-03-2024, 01:18 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
