Asus Rog G752VSK rev 2.1 bios problem
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    this came in with no display,as everything looked ok I tried bios dump(g752vsk bios CLEAR ME.bin,attached),
    the mobo booted perfectly,installed the os (win 10)but it swiched off very randomly.but my real concern is :if i upgrade it to vers3.05 on windows
    upon reboot (originally vers3.02),i have no display,repgrammed the known working (version as3.02) dump and it works again.using ez flash utility in
    bios it just stucks at the beginning of the flashing procedure,switch it off by power button(long pressing)nothing changed(still at vers 3.02).Anyone has any idea?
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    Re: Asus Rog G752VSK rev 2.1 bios problem
    Sorry wrong section.Can you move it please to the bios section?
    • myth77
      • Feb 2017
      • 380
      • Croatia
      i had similar problem with g752vs...One bios dump only worked but when i tried to update or something i get black screen. I was also loosing display/or freeze from time to time. What i did noticed is that in cpu power management monitor software the cpu consumption was arround 1.35 volt...which is very high. When i lower the voltage the laptop was working fine..but then again..if i alter something in bios or similar i had the black screen. Couldnt make it work but i believe the problem was either the cpu or pch...cpu probably 95%...I think it needed more juice to work..but never tried to replace it.
      • bachir2004
        • Feb 2015
        • 439
        • maroc
        Thanks.Can someone please build the bios with vers 305?Maybe I am doing something wrong.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12421
          ROG G752VS OC Edition (7th Gen Intel Core)
          • bachir2004
            • Feb 2015
            • 439
            • maroc
            thank you.i will try it.
            • bachir2004
              • Feb 2015
              • 439
              • maroc
              same result.no display.
              • cacla
                • Apr 2015
                • 444
                Give me sn from your unit
                • OmanCloud
                  • Aug 2023
                  • 18
                  • Oman
                  i have this laptop
                  when i connect power adapter the light is coming Solid and after 1 minute fan starting normal
                  it's looks all fine
                  ram 1.05V 3.33V 5.V all supply is Good
                  but there's no display
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • cr4zychriss
                  by cr4zychriss
                  • Rebrand: PC Specialist
                  11-14-2025, 04:04 PM
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
