Error 2204 thinkpad L13
+ More Options
Posts
  • kadsinfo
    • Dec 2017
    • 62
    • maroc
    hello
    i patched bios all work but i have Error 2204 :System configuration data is invaid.
    can you any one help me
    thanks
  • hoaca388
    Badcaps
    • Jan 2022
    • 11768
    Re: Errr 2204 thinkpad L13
    Originally posted by kadsinfo
    hello
    thanks
    Serial number ?
      • 20961
      hello
      thanks
      Add the DMI info https://www.badcaps.net/forum/showpo...43&postcount=5
      • kadsinfo
        • Dec 2017
        • 62
        • maroc
        Originally posted by hoaca388
        Serial number ?
        Serial number : R9-13QG1V
        type de number : 20R4-S3FJ0G
        • kadsinfo
          • Dec 2017
          • 62
          • maroc
          Originally posted by SMDFlea
          I did the steps in this link, my gives the same error
          • kadsinfo
            • Dec 2017
            • 62
            • maroc
            Originally posted by smdflea
            • kadsinfo
              • Dec 2017
              • 62
              • maroc
              Can y help me
              • apostsamking
                • Dec 2017
                • 117
                • Ghana
                I have the same problem after patching my Thinkpad L13. Error 2204. Any help
              • hoaca388
                Badcaps
                • Jan 2022
                • 11768
                L13 Laptops (ThinkPad) - Type 20R4
                • sosit
                  • Feb 2023
                  • 40
                  • oman
                  Not working sir
                  not turn on
                  only poer button blink 3 times
                  any other file sir
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1226
                    • France
                    try clear EC Dump
                    save serial info and others number
                    (picture of bios menu and read and save with photo block1 to 6 this utility)
                    clear ec dump with utility and restore number
                    the error is not linked to the serial number or the model. It is an error of a block where there is uuid I believe.
                    • sosit
                      • Feb 2023
                      • 40
                      • oman
                      Error 2204: System configuration data is invalid
                      If anyone facing this iisue
                      pls check this link
                      Ithink it will Help you
                      https://www.badcaps.net/forum/troubl...q=error%202204
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1226
                        • France
                        pls check this link
                        yes it corresponds to what was said,
                        initialized eeprom and saved the information before​
                        • apostsamking
                          • Dec 2017
                          • 117
                          • Ghana
                          the U1 Key Updater software cannot format my Pendrive. when i click on format tool, a warning notice, telling me all Data on the selected usb will be lost, when i press continue my usb is still not formatted. all files are on it. what should i do
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1226
                            • France
                            Try use format tools and copy content of U1 in usb key after
                            • apostsamking
                              • Dec 2017
                              • 117
                              • Ghana
                              ok will try
                              • apostsamking
                                • Dec 2017
                                • 117
                                • Ghana
                                IT worked
                                • Phan Thành
                                  • Mar 2025
                                  • Da Nang
ID:	3602536​i cant go, verification failed help me
                                  • peste
                                    peste commented
                                    Editing a comment
                                    what should we do with this picture??what's your problem??
                                • peste
                                  • Dec 2016
                                  • 12835
                                  • ROMANIA
                                  post S/N, full name and model, motherboard model, TYPE,etc.
                                  post the contents of the bios chip even if it is corrupted..
                                  Don't post pictures unless asked...
                                  read the forum rules..
                                  https://www.badcaps.net/forum/troubl...ore-posting​
                                  • Maxpower3
                                    Brand name and Model Type for Lenovo error 2202 product name is invalid
                                    by Maxpower3
                                    Info for error 2202 LenovoThinkPad models and type
                                    Extract from ThinkPad Maintenance Utilities Configuration File
                                    plnsrv.ini Version 1.01
                                    Some information that may be useful
                                    There must also be missing models, add them to the list if you know of any.
                                    Code:
                                    brand name
                                    20B1=ThinkPad Edge E445
                                    20B2=ThinkPad Edge E545
                                    20BC=ThinkPad Edge E145
                                    20BM=ThinkPad X140e
                                    20BL=ThinkPad X140e
                                    20A3=ThinkPad X230s
                                    20AH=ThinkPad X230s
                                    20AK=ThinkPad X240s
                                    20AJ=ThinkPad X240s
                                    02-21-2024, 10:27 AM
                                  • fredyjbi
                                    please help friends thinkpad T470 error post "bottom cover tamper detection error"
                                    by fredyjbi
                                    please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
                                    I've already
                                    flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
                                    06-15-2024, 09:56 AM
                                  • Sus256
                                    HISENSE 65E7KQ PRO - no boot
                                    by Sus256
                                    Hi all!
                                    HISENSE 65E7KQ PRO
                                    RSAG7.820.13512 - chassis
                                    MT9618BAATAB - cpu
                                    RSAG7.820.12059 - power
                                    HD650Y3U77 - panel
                                    KLM8G1GETF - emmc
                                    The TV does not turn on, the standby indicator is on. All voltages are present.
                                    Emms is dead. Not readable, not detected.
                                    Replaced emmc.
                                    But with another dump there is no launch
                                    Terminal log
                                    UART
                                    AC_ON
                                    RPMB key is not yet programmed
                                    HASH1_VERSION=0x00000000 64bit
                                    E-B
                                    FDE enabled
                                    layout pattern onebin by SAR7,0...
                                    06-01-2025, 02:11 AM
                                  • Marco_compucell
                                    Thinkpad P15s Gen 2 Error 2203 System configuration is invalid
                                    by Marco_compucell
                                    Gooday
                                    I have an Lenovo ThinkPad P15s gen2 that keeps giving me this error 2203
                                    I have used the Lenovo Gold Key U1 Tool erased the eeprom and enter all the configs again but I still receive this error
                                    I believe it to be an BIOS problem
                                    I will Attach bios dump and some screen shots
                                    Board number: HT4B0 /HP4B0 /HT5B1 /HT4B2 NM-D352 Rev 2.0
                                    SN: PF-3R33ZC
                                    Type Number: 20W7-S2L700...
                                    04-26-2024, 02:32 AM
                                  • SageHappy
                                    Lenovo Thinkpad 11e showing "Thermal sensing error" upon powering on.
                                    by SageHappy
                                    Hello guys,
                                    I hope you are all good. One day my Lenovo thinkpad 11e laptop just started displaying "Thermal sensing error" after I switched it on. At first I thought it was an issue to do with a defective thermal sensor in my fan. I replaced the old fan with another used fan but, the problem still persists. From where I bought the fan, they said the fan was working just fine so, my question is how can I rectify this problem. Thank you in advance.
                                    05-27-2024, 12:35 PM
