i have an hp 17-121wm that restarts any time i want a load windows or any operating system. all signs and troubleshooting leads to the bios. would appreciate if anyone could help with the bios dump. my backup is below
can anyone help with me hp 17-121wm bios
Re: can anyone help with me hp 17-121wm bios
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
I wanted to chime in and state I have the same issue and when i try to load this BIOS downloaded it states that the BIOS verification file could not be found. I attempted a stock BIOS (only one I could find) and it did the same thing. I had to attempt the update through the HP Diagnostics hub because the computer is just boot looping after a blue screen system error I believe it was AMI BIOS ERROR. If anyone could help me it would be greatly appreciated. Thank you in advance!
Kyle
Kyle
post the contents of the bios chip even if it is corrupted..
Every donation made will go towards server fees and maintenance costs.Comment
KyleComment
i have an hp 17 pavilion g121wm 17 keeps restarting every 30 seconds, it says acpi bios error stop, i think its a hardware problem??? cant do system recovery f9-f10 f11 system recovery wont work ,is it motherboard problem, restarts after auto repair f10 bios wont accept my usb recovery drive, please help.Comment
i have an hp 17 pavilion g121wm 17 keeps restarting every 30 seconds, it says acpi bios error stop, i think its a hardware problem??? cant do system recovery f9-f10 f11 system recovery wont work ,is it motherboard problem, restarts after auto repair f10 bios wont accept my usb recovery drive, please help.Last edited by skhott; 07-04-2025, 11:13 AM.Comment
post the contents of the bios chip even if it is corrupted..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
HiTechComputers thank you for your post.I follow your steps in bios and was able to install windows 11 on my hp 17-g121wm laptop.I was having acpi bios error before but now im able to install windows and update my drivers.Again thank you for your post it was a blessing .Comment
I really appreciate the fast response from you I truly do. I was experimenting in the middle of the night and found that if I set BIOS to default and then set the TPM to hidden I was able to get it to install an old version of Windows 10 from a USB drive I am currently completing the install so once it is complete I am going to immediately update the BIOS and other hardware drivers to prevent this same issue as I understand that is the cause is incompatibility between the OS and the BIOS because of its age. its an HP 17-121WM with bios version .45 I believe. I will keep you posted on my progress and again thank you so much for your response!
KyleComment
KyleComment
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
- Loading...
