can anyone help with me hp 17-121wm bios
  • Tjaytony
    • Oct 2020
    • 114
    • Nigeria
    i have an hp 17-121wm that restarts any time i want a load windows or any operating system. all signs and troubleshooting leads to the bios. would appreciate if anyone could help with the bios dump. my backup is below
  • hardware1
    • Sep 2021
    • 2951
    • N/A
    Re: can anyone help with me hp 17-121wm bios
    Here's your new file, try and let me know.
    all donations are welcome,
    • Tjaytony
      • Oct 2020
      • 114
      • Nigeria
      Tnx man, it works perfectly
      • HiTechComputers
        • Jul 2025
        • 3
        I wanted to chime in and state I have the same issue and when i try to load this BIOS downloaded it states that the BIOS verification file could not be found. I attempted a stock BIOS (only one I could find) and it did the same thing. I had to attempt the update through the HP Diagnostics hub because the computer is just boot looping after a blue screen system error I believe it was AMI BIOS ERROR. If anyone could help me it would be greatly appreciated. Thank you in advance!
        Kyle
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          Kyle
          post S/N, full name and model, motherboard model, product number,etc.
          post the contents of the bios chip even if it is corrupted..
          • HiTechComputers
            • Jul 2025
            • 3
            I really appreciate the fast response from you I truly do. I was experimenting in the middle of the night and found that if I set BIOS to default and then set the TPM to hidden I was able to get it to install an old version of Windows 10 from a USB drive I am currently completing the install so once it is complete I am going to immediately update the BIOS and other hardware drivers to prevent this same issue as I understand that is the cause is incompatibility between the OS and the BIOS because of its age. its an HP 17-121WM with bios version .45 I believe. I will keep you posted on my progress and again thank you so much for your response!
            Kyle
            • trilanth
              • Jun 2025
              i have an hp 17 pavilion g121wm 17 keeps restarting every 30 seconds, it says acpi bios error stop, i think its a hardware problem??? cant do system recovery f9-f10 f11 system recovery wont work ,is it motherboard problem, restarts after auto repair f10 bios wont accept my usb recovery drive, please help.
              • peste
                • Dec 2016
                • 13924
                • ROMANIA
                • skhott
                  • Jul 2025
                  Same exact laptop and problem. Google searching brought me here. Hoping for a solution. I have managed to get it to boot a ventoy drive and attempted a clean install of various windows versions but all reboot after launching the install wiht blue screen acpi bios error.
                  • peste
                    • Dec 2016
                    • 13924
                    • ROMANIA
                    • joe lopez
                      • Oct 2024
                      • usa
                      HiTechComputers thank you for your post.I follow your steps in bios and was able to install windows 11 on my hp 17-g121wm laptop.I was having acpi bios error before but now im able to install windows and update my drivers.Again thank you for your post it was a blessing .
                      • skhott
                        • Jul 2025
                        Kyle
                        This was my solution as well. Thank you!
                        • Darksabre
                          • Nov 2016
                          Kyle
                          I was also able to get past the blue screen loop by setting TPM to hidden in the bios. Amazing. Thank you.
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • cr4zychriss
                            by cr4zychriss
                            • Rebrand: PC Specialist
                            11-14-2025, 04:04 PM
                          • pirati
                            by pirati
                            10-27-2025, 04:20 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • istvanszasz99
                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                            by istvanszasz99
                            Product Name: Razer Blade 15 (2022)
                            Product ID: RZ09-0421
                            Motherboard: CH580
                            BIOS Versions I work with: 2.02 & 2.06
                            Bios File Size: 32,768 KB
                            Dear Forum Readers!
                            I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                            I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                            The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                            !!! MY RAZER BLADE...
                            11-24-2025, 05:52 PM
