Asus zenbook duo UX481F
  • Yeti
    • Oct 2022
    • 14
    I bought a zenbook that has a bios password, cant go into recovery. so i have used a programmer to get the bios from the chip. winbond 25Q128JVPQ. I thought i could flash a new bios image onto it but it seems like the file is too big and needs to be edited. i have opened both bios files in UEFItool but could not work out how to do it. after spending hours searching i need help!
    i have attached the original and newest bios from asus for this laptop.
    cheers.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12420
    Re: Asus zenbook duo UX481F
    cheers.
    unlocked
    • Yeti
      • Oct 2022
      • 14
      Thanks hoaca388 so much. It worked. Really appreciate your help.
      Ross
      • jc_cuerdo
        • Sep 2020
        • 13
        • Philippines
        can i used the unlocked bios to no power?? i suspect maybe its bios issue also
        • Hccp777
          • Sep 2025
          • United kingdom
          cheers.
          I know this is a old post, but what programmer u used ? I got this exact issue. Can you help me with all steps please ? Many thanks
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • corrize
            Asus zenbook duo UX481F bios pls ?
            by corrize
            Hello, when a laptop try to start with « all system power good » signal ok, and shut down, that could be a bios issue pls ?
            And there is a way to see in the bios file if the program is corrupted ?
            If it is relevant, could you provide the bios file for the Asus Zenbook DUO UX481F i7-10510U - 16Go with Nvidia MX250 2Go
            Motherboard : UX481FL Rev 2.0
            If I have to desolder the chip, I will post the bios file here.
            I add : someone requested bios file here, and don't know if I can use this file ?
            https://www.badcaps.net/forum/showthre...
            05-03-2023, 04:56 PM
