Bios lenovo idepad 3-14igl, 3-15igl, 3-15igl05 NM-C961 rev 1.0
use peste 's bios image from post 8 and transfer DMI to adress mentioned in his post----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Someone please had a look to this bios dump, it's not detecting a drive attached to M.2 slot or sata port and confirmed that all the drive i tried is working on other unit.
i've try bios from post #8 but the result still the same, tried also reflowing cpu & M.2 slot without any changes. just to convince myself the fault not in bios section
IdeaPad 3 14IGL05
SN: PF32K3C2Comment
IdeaPad 3 14IGL05
SN: PF32K3C2
​Attached Files↵
​https://www.badcaps.net/donateComment
Please help,
I need bios for Lenovo Ideapad 3 14IGL kode board NM-C961 rev 1.0... gs453 gs553
Problem is lenovo stuck logo no boot​Attached FilesComment
Update :
V14-IGL, V15-IGL, ideapad 3-14IGL05, ideapad 3-15IGL05
Version : DVCN34WW
DMI : 483000 - 484FFFAttached FilesComment
Hello please clearME. thanks in advance!
Ideapad 3 14GL05
model name 81wh
sn PF39G836
MTM 81WH009TPH
NM-C961
GS453/GS553
REV:1.0Attached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Laptop-Ideapad 3 15iglo5(81wq)
Motherboard- GS453/GS553 nm-c961 rev 1.0
19-12-27
SN: PF2J3B2W
MTM: 81WQ004PIN
BIOS CHIP-WINBOND 25Q64JWSIQ2036
**PROBLEM- Some time caming diplay and logo showe and black screen
Or some time no display
you have everything you need at post #8...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by 1g0rHello everyone,
First, the data in brief:
Manufacturer: Lenovo
Model: ThinkPad L15 G3 21C3-0016GE
motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
IC Bios 1: MX77L25650F
IC Bios 2: MX25L25673G
EC Chip: NPCX997KAABX
So far I've been a silent reader, but now I need your help
I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge - Loading...
