ideapad gaming 3 15ihu6 need bios
    • 20844
    Originally posted by mateusassuncao
    so, my CI is 25Q80EMSIG...
    only 1 MB!!!
    Could it have been replaced at another service center?
    In other words, this IC arrived here for me, with a 1MB capacity.
    Could you tell me what the original IC is, this UG2?
    The model.
    UG2 from the link i posted is 25q16jw ,it`s a 1,8V chip. I`m not sure what the 25Q80EMSIG is . Read the part number on top of the chip and confirm if it does say EMSIG or something else
    • mateusassuncao
      • Nov 2024
      • 29
      • Brasil
      #82
      25Q80EWSIG
      • m1ch43lzm
        • Mar 2019
        • 410
        • Peru
        #83
        Try this one, the UG2 from first post is for RTX 3050 Ti Mobile (PCI ID 10DE:25A0)
        According to the PCI ID from GPU-Z 10DE:1F9D, this one should work for GTX 1650, and it's 1MB
        • mateusassuncao
          • Nov 2024
          • 29
          • Brasil
          #84
          Write Thais filé, but, card dont recognized any specificatiins....
          • m1ch43lzm
            • Mar 2019
            • 410
            • Peru
            #85
            Try this one, if that doesn't work you need to find someone with the same model laptop (Ideapad Gaming 3-15IHU6) and same GPU (GTX 1650) and dump the VBIOS with GPU-Z
            • AJ_1
              • Oct 2023
              • 15
              • Ghana
              #86
              MY SSD M.2 NOT DETECT
              Ideapad Gaming 3 15IHU6
              G0G10 LA-L161P Rev: 1A
              S/N: MP2D1E07
              MTM: 82K101G3RA
              • shiyab
                • Sep 2023
                • 1445
                • india
                #87
                S/N: MP2D1E07
                MTM: 82K101G3RA
                hi try
                • doivaythoiem
                  • Jun 2024
                  • 103
                  • Việt Nam
                  #88
                  S/N: MP2D1E07
                  MTM: 82K101G3RA
                  TRY
                  • m1ch43lzm
                    • Mar 2019
                    • 410
                    • Peru
                    #89
                    mateusassuncao you're lucky, the post by AJ_1 has the 1MB VBIOS you need for GTX 1650
                    AJ_1 flash the 8MB file from posts above, it contains the ME region
                    EDIT: Both GOG10 "A" and GOG10 "B" extracted BIOS are binary identical
                    • mateusassuncao
                      • Nov 2024
                      • 29
                      • Brasil
                      #90
                      Hi, tanks for reply!
                      The new chip I replaced has a different ending. The one on the board was a 25q80ewsig.
                      The one I installed is a 25q80BVSIG.
                      Could this be the cause of the GPU memory and BIOS version not being recognized? look for my print...
                      PS. In the file pack you sent me in A or B, there's a 160kb file. Would that be the one that would work with VBIOS?
                      This file is Vbios? 160kb?
                      I'll ask for another BIOS. As soon as it arrives, I'll save the .bin file... But, would it be the 1MB file a friend posted? Or yours that came in the 160KB pack? I saw that the GPU ID in gpu-z contains the file I attached. In this case, I'm not sure which one to use: your 160KB one or the 1MB one!
                      • m1ch43lzm
                        • Mar 2019
                        • 410
                        • Peru
                        #91
                        Use the original chip W25Q80EWSIG it's 1.8V flash chip, make sure your programmer supports 1.8V chips
                        Your replacement W25Q80BV is 3.3V, won't work, that's why it is not detected
                        According to schematics you can also use MX25U8035FM2I
                        Or take a similar BIOS chip from a dead GTX 1650/1660 or RTX 20xx series desktop GPU, check datasheet first
                        https://www.badcaps.net/forum/troubl...41#post3693541
                        Post 86, he has the same GPU GTX1650 as you, use AJ_1's "old 1mb.bin" file, that's why I said you're lucky someone with the same laptop made a copy of it
                        The one I attached In post 85 I downloaded from TPU, it may work but it's an older version
                        The 160KB file from hoaca388 post is for the EC, not needed
                        • mateusassuncao
                          • Nov 2024
                          • 29
                          • Brasil
                          #92
                          Thank you very much for your feedback and clarification.
                          I bought the correct adapter and chip!
                          I'll post the results as soon as they arrive!
                          • AJ_1
                            • Oct 2023
                            • 15
                            • Ghana
                            #93
                            Originally posted by shiyab
                            hi try
                            Pls boss I flash both 2 files but no display, I use old 8MB file then Display come, but still m.2 is not detect
                            • AJ_1
                              • Oct 2023
                              • 15
                              • Ghana
                              #94
                              Originally posted by doivaythoiem
                              TRY
                              • danito
                                • Jun 2016
                                • 911
                                • Romania
                                #95
                                try
                                • AJ_1
                                  • Oct 2023
                                  • 15
                                  • Ghana
                                  #96
                                  Originally posted by danito
                                  try
                                  pls no display
                                  • mateusassuncao
                                    • Nov 2024
                                    • 29
                                    • Brasil
                                    #97
                                    As promised.
                                    Here are the screenshots!
                                    Many thanks to the colleagues who helped so much with the repair! Great community!
                                      Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                      09-07-2024, 05:20 AM
                                      Lenovo IdeaPad Gaming 3 15IHU6 Notebook G Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad Gaming 3 15IHU6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 15IHU6 boardview and Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 06:31 AM
                                      Lenovo IdeaPad Gaming 3 15IHU6 Notebook 3 Specification for Upgrade or Repair
                                      09-07-2024, 04:30 AM
                                      Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-07-2024, 05:00 AM
                                    • grimacelord
                                      by grimacelord
                                      07-10-2025, 02:52 PM
