Dell Latitude 5430, LA-L591P Computrace setting unlock
  • its service
    • Feb 2021
    • 141
    • india
    #481
    Originally posted by peste
    both..
    Dell latitude 5430
    Part no : La-L591p rev 1.0
    ST no : 6hk96vk3
    both file attached sir
    • danito
      • Jun 2016
      • 1003
      • Romania
      #482
      Originally posted by its service
      Dell latitude 5430
      ST no : 6hk96vk3
      ST is wrong, it's too long
      • bhcomputadores
        • Jun 2017
        • 24
        • Brazil
        #483
        Hello! I tested some files from this post but was unsuccessful. The machine even stopped turning on after one. Can you try removing the administrator password from these files that I backed up before testing the ones from this forum?
        I thank you in advance!! dell latitude 5430 ST: 8BL2PT3 MB:HDB42 LA-L591P REV 1.0 A00 2022-01-13
        Last edited by bhcomputadores; 07-24-2025, 07:18 AM. Reason: I FORGOT TO PUT THE EQUIPMENT MODEL
      • bhcomputadores
        • Jun 2017
        • 24
        • Brazil
        #484
        CORRECTED SMDFlea Sorry!
          • 21186
          Read the dell bios password post https://www.badcaps.net/forum/troubl...23#post1622423 you might be able to unlockit yourself, it depends what the suffix is.
          • LBTT1121
            • Nov 2024
            • 608
            • Việt Nam
            #486
            try
            • bhcomputadores
              • Jun 2017
              • 24
              • Brazil
              #487
              Originally posted by LBTT1121
              try
              Muito obrigado! thanks a lot!😁
              • bhcomputadores
                • Jun 2017
                • 24
                • Brazil
                #488
                I followed the process described in the post you mentioned and it worked! Thank you!
                • marquitos550b
                  • Nov 2011
                  • 22
                  #489
                  Originally posted by volinakis
                  Re: Dell Latitude 5430, LA-L591P Computrace setting unlock
                  try. 1st boot press F2, write Service Tag, disable Absolute, save, restart. 2nd boot press alt+F to exit manufacturing mode.
                  Thank you !!!
                  • Bios White
                    Learn
                    • Dec 2024
                    • 72
                    • East Laos
                    #490
                    dell latitude 5430
                    ST: 8BL2PT3
                    Laptop no display, please build bios
                    many thank
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11891
                      #491
                      Originally posted by Bios White
                      dell latitude 5430
                      ST: 8BL2PT3
                      many thank
                      Latitude 5430_ADL
                      Service Tag: 8BL2PT3
                      • dahnking
                        • Apr 2018
                        • 258
                        • kenya
                        #492
                        Try
                        Working, Thank you
                        • Bios White
                          Learn
                          • Dec 2024
                          • 72
                          • East Laos
                          #493
                          Latitude 5430_ADL
                          working 100% , thank you
                          • LANTEc
                            • ZAMBIA
                            #494
                            ST: 89JJKR3
                            *BIN compressed
                            • Edonhiran
                              • Jun 2025
                              • United Kingdom
                              #495
                              I have a Dell Latitude 5430 laptop that currently has a BIOS password set, and I need to remove it need help please.
                              Here are the device details:
                              • Model: Dell Latitude 5430
                              • Service Tag: 2H3YKR3
                              Thank you in advance!...
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11891
                                #496
                                3.4. Dell
                                Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                                See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                                Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                                Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                                Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                                Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                                Note: There is no publicly available 8FC8 generator available at the moment.
                                The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                                8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                                • Edonhiran
                                  • Jun 2025
                                  • United Kingdom
                                  #497
                                  3.4. Dell
                                  I have tried to flash bios chip and I used one of bin file from this post above. . But it didn't work. unfortunately now laptop not responding and just power light for few seconds. Also mistakenly deleted original bios bin file. Please I need help to resolve this.
                                  Thank you
                                  • user392097
                                    • Jun 2023
                                    • 10
                                    • Georgia
                                    #498
                                    Hello. Please help me to restore the BIOS.
                                    After patching the dump with Badcaps/Rex_8FC8_Patcher to remove the password and flashing it back the laptop doesn't boot.
                                    Flashing original BIOS dump gives the same result. I think that the dump is defective.
                                    Dell Latitude 5430 12th gen
                                    HDB42 LA-L591P Rev:1.0(A00)
                                    Service Tag 1C7CWT3
                                    Winbond 25Q256JVEN
                                    Original dump is attached.
                                    • kaput
                                      Lenovo Thinkcentre M720q, disable activated Computrace
                                      by kaput
                                      Not a BIOS request per se, but closely related. Please bear with me
                                      A while ago I found an old Lenovo Thinkcentre M720q in pieces in the electronics scrap bin at work. There was only some minor damage to the case, so collected everything and brought it home to let it dry and see if it still worked. It did
                                      Unfortunately Computrace has been activated on it. Since I'm using it as an emulation console with Lakka now, it's no big deal, but would be nice to get rid of the annoying message popping up when entering the UEFI setup, and also learn something along the way....
                                      06-28-2024, 09:36 AM
                                      HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation E5430 Specification for Upgrade or Repair
                                      This specification for the HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                      09-12-2024, 03:36 PM
                                      DELL Latitude 5430 Notebook 5000 Specification for Upgrade or Repair
                                      This specification for the DELL Latitude 5430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5430 boardview and 5430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5430...
                                      09-07-2024, 06:31 AM
                                    • Syseng
                                      Lenovo P14s Gen 5 SVP unlock
                                      by Syseng
                                      This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                      The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                      06-22-2025, 07:44 AM
