I nedd this bios
Need bios thinkpad T14,T15 Gen 2 nm-d352, nm d353 rev 2.0
Re: Need bios nm-d352 rev 2.0
TryAttached FilesComment
Hello. Need bios dump for Lenovo t14Attached FilesComment
Hello, does anyone have a working bios for Lenovo Thinkpad P15s nm-d352 rev 2.0 SN: PF-3FQ9Q6 TYPE NUM: 20W7-S1UL00, attached, its original bios boots without an image.Attached FilesComment
A reminder
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
ThinkPad P14s Gen 2
sn: pf-3j9rv8
type n:20vx-009quk
powers on, fan don't spin, no display. Please fix.Attached FilesComment
Hello Sir
Good Morning
I have Lenovo T15 Gen 2 the Problem is this its showing just lenovo logo and blank when i press F1 its showing entering Setup then again Blank i think its bios Issue Please Check this
MotherBoard Code :-NM-D352 rev 2.0
serial Number :- PF-3BLG4T
THANKS IN ADVANCEAttached FilesComment
Hello, I suspect that my thinkpad t15 gen 2 bios file is corrupted. If you have it, can you help me? The files are attached. Motherboard code nm-d353 rev 1.0 serial no: PF-3MPZKE TYPE 20W5Attached FilesComment
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
Channel: BIOS Requests ONLY!
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
- Loading...
