Dell latitude 7410 8fc8 bios password
  • vidvansh
    • Mar 2025
    • 26
    Can someone help me remove the bio password
    Dell Lattitude 7410
    SERVICE TAG:HL3DFB3
    BOARD:BOARD~FDX40 LA-J261P REV:1.0(A00)
    • peste
      • Dec 2016
      • 13573
      • ROMANIA
      #122
      Dell Lattitude 7410
      SERVICE TAG:HL3DFB3
      try..
      • vidvansh
        • Mar 2025
        • 26
        It did not work. Led is flashing orange when pressing power button. nothing else happening.
        • peste
          • Dec 2016
          • 13573
          • ROMANIA
          #124
          write the original content back to the chip, see what happens...
          • vidvansh
            • Mar 2025
            • 26
            I wrote the original file to the chip. It is booting fine. I think there is some issue with the patched file. Is there anything else you want me to try.
            • Markus1741
              • Sep 2020
              • 946
              • N/A
              #126
              Hello you can try this new file from your original file good luck ...
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                #127
                1st boot, press F2, write service tag, disable Absolute, save, restart.
                2nd boot press Alt+F to exit manufacturing mode.
                Good luck.​
                • vidvansh
                  • Mar 2025
                  • 26
                  Good luck.​
                  I tried this file. It did not worked for me. I will try another file posted above to see if it works.
                  Is there any easy way to read write wson8 chips?? Like any probe which can be used on dell laptops as bios chips on dell 7410 does not have legs to make contact with a probe. It is really hard to desolder and solder chip again and again.
                  • lapfix
                    • Mar 2020
                    • 2764
                    • my workshop
                    #129
                    I m sure that my file is unlocked and must be work if thersn't another hardware issue .
                    You can search by this words for a probe for this QFN chip : Qfn8 Dfn8 Wson8 Ic Test Clip Probe
                    • bejaoui
                      • Feb 2017
                      • 61
                      • ariana
                      #130
                      Re: Dell latitude 7410 bios password
                      Please unlock bios password
                      • lapfix
                        • Mar 2020
                        • 2764
                        • my workshop
                        #131
                        bejaoui
                        Good luck.
                        • stakrzysiu
                          • Sep 2016
                          • 18
                          this i my Dell 7410 bios. It´s locked.
                          STag: D4T6FB3
                          Can you unlock it for me?
                          Thank you.
                          BR
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12326
                            #133
                            STag: D4T6FB3
                            Thank you.
                            BR
                            Unlocked
                            ​https://www.badcaps.net/donate
                            • peste
                              • Dec 2016
                              • 13573
                              • ROMANIA
                              #134
                              STag: D4T6FB3
                              Thank you.
                              BR
                              try..
                              • stakrzysiu
                                • Sep 2016
                                • 18
                                Originally posted by peste
                                try..
                                Worked! Thank you very much!!!
                                • zlr8r
                                  • Feb 2023
                                  • 91
                                  Hey guys, could some kind soul remove password from my Bios file please ?
                                  I read the XMC-QH256BXIQ Bios chip using 2 programmers, CH341a , and a XGecu TL866ii+, verified and saved 2 copies.
                                  I tried running both copies through the various Dell password Utils, but it just kept saying, "intel Signature Not Found" , or, "8FC8 Hex Pattern not Found"...? What am i doing worng ?
                                  • Is there another Util i can use to easily find the Bios Passwords myself, and to save me annoying you guys ?
                                  LAPTOP: Dell Latitude 7410
                                  SERVICE TAG: CX2MN73-8FC8
                                  BOARD: FDX40 LA-J261P REV:1.0(A00)
                                  thanks in advance
                                  • zlr8r
                                    • Feb 2023
                                    • 91
                                    thanks in advance
                                    ..anyone able to help ?
                                    • peste
                                      • Dec 2016
                                      • 13573
                                      • ROMANIA
                                      #138
                                      try again with TL866II, but like this...
                                      The bios chip must be unsoldered from the board before writing or reading..
                                      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                                      solder wires between the programmer and the bios chip..
                                      and post again..
                                      here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                      • zlr8r
                                        • Feb 2023
                                        • 91
                                        and post again..
                                        that is the the exact method i used , file already uploaded. 😙
                                        both BINs where identical and verified.
                                        • zlr8r
                                          • Feb 2023
                                          • 91
                                          ...please advise
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 7410 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7410 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7410 boardview and 7410 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7410...
                                            09-06-2024, 08:10 PM
