Owners of X1 Extreme Gen 2 w/ i9 Processor I Need BIOS Dump
  • elzorroazul777
    • Sep 2022
    • 28
    Re: Owners of X1 Extreme Gen 2 w/ i9 Processor I Need BIOS Dump
    Originally posted by SMDFlea
    Here`s the bios with clean ME firmware
    Here's another dump, not from Vinafix but I believe from the same website that I found the schematic and boardview from. I put up another request on Vinafix to see if I can get any other dumps.
    I had posted on Vinafix about a week ago, I tried the BIOS ThienBui sent me but it didn't work. Maybe it needed a clear ME?
      • 21038
      Unsurprisingly it did need the ME cleaning.
      • elzorroazul777
        • Sep 2022
        • 28
        LOL
          • 21038
          LOL
          1MB Zeros.zip for thunderbolt https://www.badcaps.net/forum/attach...9&d=1641884709
          + your TB FW redone with n2otk08w
          • elzorroazul777
            • Sep 2022
            • 28
            Thank you for this. I tried both repaired TB FW and zeroed TB FW but unfortunately it wasn't enough to convince the board to turn on.
            There's a third EEPROM chip on the board just below the left hand side fan and just above the BIOS chip. This third EEPROM is a Winbond W25Q80EW 1.8v. I stuck a 1.8v adapter on the programmer and read the chip, it's zero filled but not by me. Not sure what that one does, my guess was maybe gpu? This chip does not get power when I press the power on button, whereas the MXIC chips both do get power.
            Yesterday I pulled some plastic film that was covering a portion of the motherboard on it's backside. I noticed today in a picture that there was damage to a chip beneath the board covered by that plastic. Not sure how bad the damage is or if it would prevent the computer from working.
            I think at this point, considering how much time I've spent trying to fix this that it may not be worth further investigating. I don't know if this continues to be a BIOS chip issue, a Thunderbolt 3 chip issue, an embedded controller issue, or this Winbond chip issue.
            If I was able to get life from the board, I would consider working on this further.
            Thank you for all of your help!
            I have another post up on Win-Raid forum as a last-ditch attempt for a fix. If anything changes, I'll post back here.
            https://winraid.level1techs.com/t/re...ios-dump/90783
            Last edited by SMDFlea; 10-29-2022, 11:29 AM. Reason: removed schematic.Bios requests only in the bios requests sub forum
            • elzorroazul777
              • Sep 2022
              • 28
              Another observation, I just noticed today that the bios.bin I supplied earlier from post #21 is for a Thinkpad P1 Gen 2 18809-1 with a Winbond bios chip W25Q256FV. I have a MXIC 25L25673G bios chip. The N2OET36W ME_CLEAN is based on that bios backup from the W25Q256FV. I think this explains why the motherboard remains 'dead' as the EC information is stored in the BIOS firmware and I have been unable to find a compatible binary dump.
              If anyone finds a X1 Extreme Gen 2 bios dump from a MXIC 25L25673G bios chip found on the 18809-2 LPM-2 motherboard, please send it my way
              • Ali5914
                • Dec 2020
                • 48
                • India
                #27
                Re: Did I Screw Up? Any Hope for Success? Programming BIOS CHIP
                Hi friend, if this is still pending then i can try my best to build a fresh bios for you. But i need few details like motherboard part no, cpu number and machine serial no. Please let me know.
                • elzorroazul777
                  • Sep 2022
                  • 28
                  Hey, that would be amazing!
                  Lenovo X1 Extreme Gen 2
                  • Motherboard Part Number 18809-2 LPM-2
                  • CPU part number i9 906ed
                  • Machine Serial Number S/N R9-0WXXVM 19/12
                  • Ali5914
                    • Dec 2020
                    • 48
                    • India
                    #29
                    Attaching new bios with bios and csme cleaned... Please check and comment.
                    • elzorroazul777
                      • Sep 2022
                      • 28
                      Hey thank you for trying! I wasn't able to get this to work, but there may be a malfunction with the EC on my motherboard so it's not clear to me that there is anything wrong with this BIOS file you've uploaded.
                      • dm_ax
                        • Mar 2024
                        • Mexico
                        #31
                        Lenovo P1 Gen2
                        S/N R9-0XC631
                        BIOS MX25L25673G
                        Motherboard 18809-2 LPM-2
                        CPU: Xeon E-2276M
                        It worked perfectly, everything had already been updated for more than a week, I had a 1TB SSD, I wanted to add another 1TB SSD, I got it perfectly, the only thing I noticed was that it no longer had audio and I only disabled the UEFI and the security boots
                        I turned it off and changed the position of the SSD, and it simply didn't turn on again, only the LED stays on and that's all it does.
                        I have already tried all the BIN files here and none of them worked, the LED doesn't even turn on, it doesn't respond at all.
                        I put the original BIN back in and it does the same thing again, just turning on the LED.​
                        • rui4892
                          • Mar 2017
                          • 57
                          • Portugal
                          #32
                          Hey guys.
                          There's a Thinkpad X1 Extreme 2nd on the bench, asking for a supervisor password... any solution? I tried other dumps from this topic, but the machine doesn't turn on.​
                          in attachments original dumps ( working dumps but ask por password )
                        • ngger handoko
                          • Mar 2024
                          • 29
                          • indonesia
                          #33
                          please help build bios X1 EXTREME 2ND GEN
                          mainboard code 18809-1M
                          type : 20QV-0007US
                          SN : R9-0VKQDW
                          CORE I7 GEN 9
                          Poblem no display, with melody sound once.
                          all bios here already tried, but all no power.
                          maybe different MB code? 18809-1M ( with M )
                          thankyou.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11815
                            #34
                            type : 20QV-0007US
                            SN : R9-0VKQDW
                            CORE I7 GEN 9
                            thankyou.
                            X1 Extreme 2nd Gen Laptop (ThinkPad) - Type 20QV
                            • ngger handoko
                              • Mar 2024
                              • 29
                              • indonesia
                              #35
                              Thankyou . same result, still no display with melody once . or maybe other hardware issue.
                              • duong.160694@gmail.com
                                • Nov 2017
                                • 20
                                • viennam
                                #36
                                LENOVO P1 GEN 2 (LPM-2 MB 18809-2)
                                S/N R90YD6LH
                                TYPE NUMBER 20QU-S47D00
                                PASS BIOS---HELP ME! PLS!!
                                • shiyab
                                  • Sep 2023
                                  • 1495
                                  • india
                                  #37
                                  S/N R90YD6LH
                                  pass in io
                                    Intel Core i7-900 Desktop Processor Extreme Edition Series Datasheet
                                    The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are intended for high performance high-end desktop, Uni-processor (UP) server, and workstation systems. Several architectural and microarchitectural enhancements have been added to this processor including four processor cores in the processor package and increased shared cache.
                                    The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are the first desktop multi-core processor to implement key new technologies:
                                    10-23-2024, 02:56 AM
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                    ASUS ZenBook 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                                    This specification for the ASUS ZenBook 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD boardview and 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD schematic. Our users have donated over...
                                    09-06-2024, 05:30 PM
                                  • haitham sharabati
                                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                    💀 Problem:😅
                                    - Device shows “Administrator Password”...
                                    08-07-2025, 04:54 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
