Lenovo Ideadpad gaming 3 15ACH6
  • TOMÁŠ
    • Oct 2022
    • 18
    • Spojené království
    #101
    Originally posted by questore
    None taken, we are here to help each other I think.
    My oppinion is that replacement accoring to my comparison link and your bios datasheet W25Q128JWSIQ is better for your replacement because its maximum Maximum Clock Frequency​ is up to 133Mhz and your GD25LR128D is up to 120Mhz
    (w25q128fwsig is only 104 Mhz)
    but someone correct me if I wrong.
    Thank you very much. Will update end of next week.
    • TOMÁŠ
      • Oct 2022
      • 18
      #102
      Thank you very much, all works as should.
      • Michalski124
        • Sep 2022
        • Polska
        #103
        Hello i need BIOS, i Think someone before me broke that and tried do something with flashing (soldering of chip) and now laptop only spins fans and LCD is light up but nothing on the screen. All voltages are ok, battery is chargin.
        s/n mp2e39rk
        board la-k971p v1
        laptop Lenovo ideapad gaming 3 15ach6 82k2 with 5600h and rtx 3060
        bios dump Done with ch341 with 1.8v adapter
          SMDFlea commented
          Editing a comment
          thread merged.
      • peste
        • 13747
        • ROMANIA
        #104
        s/n mp2e39rk
        board la-k971p v1
        you have everything you need at post #83...
        https://www.badcaps.net/forum/troubl...3-15ach6/page5
        The laptop has four bios versions...the laptop's bios is corrupted and the bios version cannot be found...try the versions from post 83 one by one...
        • Michalski124
          • Sep 2022
          • Polska
          #105
          Should I copy my S/N and how do I do that if required? Is it required to just boot laptop without copying anything to test?
            • 22109
            The DMI offsets don`t look right (for the 82k2) ,i think they should be
            EA5000 - EA6FFF
            EAA000 - EAA03F
              • 22109
              You can try them without the serial, it can be added later.
              • Michalski124
                • Sep 2022
                • Polska
                #108
                Another thing forgot to ask - i dont have any soldered gpu ram (someone desoldered before), without it should it post something on screen?
                • Alexinho FPS
                  Alexhsouza
                  • May 2025
                  • Brazil
                  #109
                  Can someone help me, I have a black screen, it generates the post but I have no image, all the voltages are normal, my recorder corrupted the original file, I need the file corrected please.
                  GOG21 LA-K971P
                  REV: 1A
                  2021-03-31
                  SN: PE0A9NQR
                  MTM: 82MJS00100
                  • peste
                    • 13747
                    • ROMANIA
                    #110
                    GOG21 LA-K971P
                    REV: 1A
                    2021-03-31
                    SN: PE0A9NQR
                    MTM: 82MJS00100
                    you have everything you need at post #83...GOG20305A
                    • barby16_06
                      • Jul 2014
                      • 24
                      • romania
                      #111
                      Greetings to all.
                      I have a strange problem with an Lenovo Ideadpad gaming 3 15ACH6, to be more detailed, laptop worked fine for at least 1 year and from a few days ago laptop won't boot into windows, it gives bluescreen witn ntoskrnl.exe and, tought it's from OS or hdd or even Ram, but all of those are fine, even if i try to do a fresh install with W11 it give's bluescreen with page fault in nonpaged area.
                      So tryed with a good Ram, even with another good SSD, tryed with more USB drives with media creation tool for os install, same problem. It give BSO at windows load or windows installer load.
                      next i tryed to update bios, but only chance to do it was with recovery procedure and it worked to update bios but not the EC too.
                      So to eliminate this possibility of let's say incorect EC dump or incompability from EC with Main i wanna ask you for a clean bios and EC dump.
                      If this won't work out then the only option remain that the problem to be from CPU and it should be changed/reballed.
                      if it can help, i can enter in advanced bios setup with the secquence of F2-Fn+R+N-F10-Yes-F2, maybe you got some ideeas of what i can change from there to bypass this problem (maybe increasing some voltage of Ram or CPU, or increasing some page file if exists)
                      I atached readed dumps from the MB and the official update from lenovo(H3CN47WW).
                      SN is :MP2NJ5MP
                      Mb is GOG20 LA L171P REV 1.A
                      • peste
                        • 13747
                        • ROMANIA
                        #112
                        read the post above..
                        • barby16_06
                          • Jul 2014
                          • 24
                          • romania
                          #113
                          all files from there are invalid when trying to download. and what i asked was both roms, main+ec. also the one from post 86 containst only main
                          • barby16_06
                            • Jul 2014
                            • 24
                            • romania
                            #114
                            can someone help me with requested roms? i need both 16mb and 2mb. files from post 82 are not available to download and also can't find anywhere the 2mb dump.
                            • jotati7062
                              • Jan 2024
                              • 34
                              • SA
                              #115
                              Hello everyone, i have Lenovo ideapad gaming 3 15ACH6 Bios Locked
                              I attached both Main Bios Chip + EC Chip
                              I never Done Lenovo before so if i need DMI info re added please include them and how to add them unless if easy like HP bios.
                              Lenovo ideapad gaming 3 15ACH6 Locked
                              SN: MP2BK85Q
                              Board Model: GOG20 LA-L171P Rev. 1A
                              MTM: 82K201XCUS
                              MO: MPNXB280303D
                              Factory ID: PRC4
                              Thank you
                                SMDFlea commented
                                Editing a comment
                                Thread merged.
                            • peste
                              • 13747
                              • ROMANIA
                              #116
                              SN: MP2BK85Q
                              MTM: 82K201XCUS
                              MO: MPNXB280303D
                              Factory ID: PRC4
                              Thank you
                              you have everything you need at post #83...GOG20305A...
                              • jotati7062
                                • Jan 2024
                                • 34
                                • SA
                                #117
                                hello
                                That post is only for someone with bad bios and they’re trying to fix the computer
                                I don’t see any good for it over there for me
                                The device I have is fully functional it’s just locked
                                while the other post is mentioning no display and some other issues
                                • hardware1
                                  • Sep 2021
                                  • 2949
                                  • N/A
                                  #118
                                  SN: MP2BK85Q
                                  MTM: 82K201XCUS
                                  MO: MPNXB280303D
                                  Factory ID: PRC4
                                  Thank you
                                  Try this Password for both (Power On Password & Supervisor Password)
                                  J903
                                  all donations are welcome,
                                  • peste
                                    • 13747
                                    • ROMANIA
                                    #119
                                    hello
                                    I was wrong..#82...there are bios extracted from the update on the site,....do you think they have passwords...write the bios I gave you...
                                    • jotati7062
                                      • Jan 2024
                                      • 34
                                      • SA
                                      #120
                                      J903
                                      well, I don’t know how to thank you, it worked like magic, Thank you so Much.
                                      out of curiosity is that a private method or something already here on this fourm?
                                        Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-07-2024, 05:00 AM
                                        Lenovo IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 15ACH6 boardview and Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 04:30 AM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
