hp 15s-fr2xxx
  • jacospama
    • Aug 2019
    • 240
    • Ghana
    hp 15s-fr2xxx
    this laptop cant shut down . it boots by itself 2 seconds after shutdown . i need solution .
    part no. DA0P5HMB8F1 rev f
    serial number. 5CD1409DJV
    • 20990
    Re: hp 15s-fr2xxx
    Go to the HP support site,enter your serial number.Download the bios update and run the exe. It will give an option to make a recovery USB drive or you can choose to save to a location.If you choose to save to a location all the bios will be decrypted and saved. If there is only one bios then that is what you can use.If there are multiple then you need to know which one to choose. Open your bios backup (if you have one) with a hex editor and search for the file names, sometimes they start with the word BID .You can flash the virgin bios but you will lose all DMI info.If you have a backup its relatively easy to copy all the info from the backup to the virgin bios with a hex editor,it will take you less than 5 minutes from downloading,extracting and copying the DMI.
    • jacospama
      • Aug 2019
      • 240
      • Ghana
      Re: hp 15s-fr2xxx
      tHank Sir. i have tried this but still reboot while shutting down. is there any way of solving this problem
      • lapfix
        • Mar 2020
        • 2733
        • my workshop
        Re: hp 15s-fr2xxx
        post your old dump
        • jacospama
          • Aug 2019
          • 240
          • Ghana
          Re: hp 15s-fr2xxx
          Originally posted by lapfix
          post your old dump
          THank you for your response . piease here is the file
          • hoaca388
            Badcaps
            • Jan 2022
            • 11798
            Re: hp 15s-fr2xxx
            HP Laptop PC 15s-fr2000-087FD ( Use the remaining rar file if ...-087FD does not work.)
            • jacospama
              • Aug 2019
              • 240
              • Ghana
              Re: hp 15s-fr2xxx
              tHANK YOU SENIOR. I have tried them all , all of them works but still cant shutdown. instead of shutting down, it restarts. it turns on 2 seconds after shutdown. what must i do again?
                • 20990
                Re: hp 15s-fr2xxx
                not a bios issue.
                • DanielDacko
                  • Mar 2015
                  • 325
                  • Macedonia
                  Re: hp 15s-fr2xxx
                  Probably some kind of short on some S0 rail.
                  I don't provide help for people using CH341A and a clip.
                  • hardware1
                    • Sep 2021
                    • 2936
                    • N/A
                    Re: hp 15s-fr2xxx
                    try this one. if it doesn't work, maybe its an EC firmware problem of bad SIO.
                    all donations are welcome,
                    • jacospama
                      • Aug 2019
                      • 240
                      • Ghana
                      Re: hp 15s-fr2xxx
                      Thank am gonna try . i will reply after
                      • jacospama
                        • Aug 2019
                        • 240
                        • Ghana
                        Re: hp 15s-fr2xxx
                        i tried but still boots after shut down
                        • jacospama
                          • Aug 2019
                          • 240
                          • Ghana
                          Re: hp 15s-fr2xxx
                          not a bios issue.
                          please what might be the couse?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11798
                            Re: hp 15s-fr2xxx
                            Find hardware support here : https://www.badcaps.net/forum/forumdisplay.php?f=23
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Re: hp 15s-fr2xxx
                              Open a thread in troubleshooting section and will try to help you.
                              • jacospama
                                • Aug 2019
                                • 240
                                • Ghana
                                Re: hp 15s-fr2xxx
                                thank you
                                • DiddiAb
                                  BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
                                  by DiddiAb
                                  Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
                                  I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
                                  03-11-2023, 03:15 AM
                                • Chris_stand
                                  Clevo PD50PNN won't boot after BIOS Backup
                                  by Chris_stand
                                  i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
                                  At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
                                  Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
                                  But the...
                                  04-28-2023, 03:08 PM
                                • zenius
                                  by zenius
                                  12-08-2024, 06:13 AM
                                • Wahaz
                                  by Wahaz
                                  10-30-2023, 08:42 PM
                                • Bloodhoundje
                                  by Bloodhoundje
                                  03-16-2024, 03:12 PM
