Need Asus x550jk ec bios
  • bilen
    • Aug 2014
    • 637
    • istanbul
    Motherboard code : x550jd rev 2.0
    IT8585E
    Need dump
    • 22279
    Re: Need Asus x550jk ec bios
    IT8585E
    Need dump
    Do you have a bios backup, the EC can sometimes be extracted from it. Are there any long white barcode stickers near the soldered ram, if there are post pictures of them.
    • cacla
      • Apr 2015
      • 444
      IT8585E
      Need dump
      Give me sn from the unit
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
