Panasonic CF-19ZF193BM MK8 BIOS
  • BlueJao
    • Sep 2022
    • 5
    Can anyone help me remove the password from a Panasonic CF-19ZF193BM MK8 Toughbook. I have already tried clearing the AMITSESetup variable using UEFITools to no avail. I think that this is in part because every time I open my binary with UEFItools it gives me invalid file alignment and invalid checksum errors. I've tried hours of fiddling around with it to get rid of those errors (trying various versions, dependencies, etc) to no avail! I've also tried the decryptor from this[https://www.badcaps.net/forum/showthread.php?t=102275] thread, also to no avail. I am unsure of whether or not that is an issue with the way it parses hex, since it's spitting out some interesting characters. Any help is greatly appreciated!
    I have included the password protected binary below:
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Panasonic CF-19 MK8 BIOS
    try..
    • BlueJao
      • Sep 2022
      • 5
      Originally posted by peste
      try..
      Flashed it... no dice
      Power lights come on but the screen doesn't light. The CF-19 I have has no moving parts, so I have no indication of whether or not its reaching post and just not displaying anything or not posting at all. Anything that you could think of?
      • BlueJao
        • Sep 2022
        • 5
        Any ideas? I've been fiddling with UEFItools, but I'm still SOL
          • 22276
          • BlueJao
            • Sep 2022
            • 5
            Originally posted by SMDFlea
            It works, thank you!
            Can you walk me through the process, so that I can do this by myself or for others in the future?
            • AquaMan Ua
              by AquaMan Ua
              05-17-2025, 09:40 AM
            • aa10aa10
              Panasonic Toughbook CF-33 mk1 BIOS repair
              by aa10aa10
              Good day,
              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
              01-21-2025, 06:13 AM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • cr4zychriss
              by cr4zychriss
              • Rebrand: PC Specialist
              11-14-2025, 04:04 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
