Panasonic CF-19ZF193BM MK8 BIOS
  • BlueJao
    • Sep 2022
    • 5
    Can anyone help me remove the password from a Panasonic CF-19ZF193BM MK8 Toughbook. I have already tried clearing the AMITSESetup variable using UEFITools to no avail. I think that this is in part because every time I open my binary with UEFItools it gives me invalid file alignment and invalid checksum errors. I've tried hours of fiddling around with it to get rid of those errors (trying various versions, dependencies, etc) to no avail! I've also tried the decryptor from this[https://www.badcaps.net/forum/showthread.php?t=102275] thread, also to no avail. I am unsure of whether or not that is an issue with the way it parses hex, since it's spitting out some interesting characters. Any help is greatly appreciated!
    I have included the password protected binary below:
  • peste
    • 12542
    • ROMANIA
    Re: Panasonic CF-19 MK8 BIOS
    try..
    • BlueJao
      • Sep 2022
      • 5
      Originally posted by peste
      try..
      Flashed it... no dice
      Power lights come on but the screen doesn't light. The CF-19 I have has no moving parts, so I have no indication of whether or not its reaching post and just not displaying anything or not posting at all. Anything that you could think of?
      • BlueJao
        • Sep 2022
        • 5
        Any ideas? I've been fiddling with UEFItools, but I'm still SOL
          • 20609
          • BlueJao
            • Sep 2022
            • 5
            Originally posted by SMDFlea
            It works, thank you!
            Can you walk me through the process, so that I can do this by myself or for others in the future?
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
            • aa10aa10
              Panasonic Toughbook CF-33 mk1 BIOS repair
              by aa10aa10
              Good day,
              I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
              I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
              01-21-2025, 06:13 AM
              by Vesko356
              08-11-2023, 03:27 AM
            • James Jackson
              Panasonic CF-20G0247VM BIOS Bad Flash Help
              by James Jackson
              I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
              Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
              05-01-2025, 11:28 AM
            • outsider
              Panasonic FZ-G1 MK5 - BIOS password returning
              by outsider
              Hello
              I removed the BIOS password thanks to the help of one of the friends of this forum.
              https://www.badcaps.net/forum/troubl...61#post3637661
              The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
              06-17-2025, 12:51 AM
