Fujitsu E459 Bios Dump
  • Repdata
    • May 2020
    • 67
    • Deutschland
    Hello
    After a bios update of my Fujitsu E459, the USB ports no longer work
    in bios will too
    MCU version no connection information is displayed
    I am thankful for every help
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Fujitsu E459 Bios Dump
    Originally posted by Repdata
    Hello
    in bios will too
    try
    • Repdata
      • May 2020
      • 67
      • Deutschland
      @Lapfix
      Thank you very much I will give you feedback
      @lapfix
      USB ports work
      Thanks again
      Unfortunately, I was happy too early, the M2 is no longer recognized
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Lifebook e459
          • 22279
          try this one.
          • Repdata
            • May 2020
            • 67
            • Deutschland
            thank you I will test and give feedback
            • Repdata
              • May 2020
              • 67
              • Deutschland
              I tested both files
              Unfortunately, the USB ports do not work
              thanks for the work
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • MohammedBathabet
                Request BIOS dump for Fujitsu LIFEBOOK AH47/J (DAFH6BMB6A0)
                by MohammedBathabet
                I need a BIOS dump file for my Fujitsu LIFEBOOK AH47/J laptop.
                Motherboard model: DAFH6BMB6A0
                The system BIOS got corrupted and now the laptop powers on but does not boot.
                I already tried the official Fujitsu support site, but the downloadable BIOS is only in .exe format and does not contain the raw .bin file needed for programming the BIOS chip directly with a programmer (CH341A).
                If anyone has a working BIOS dump (.bin) for this model, please share it.
                Thanks in advance!...
                09-24-2025, 05:59 AM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • yotoprules
                Fujitsu Amilo Pro V2030D BIOS DUMP
                by yotoprules
                I am looking for Fujitsu Amilo Pro V2030D BIOS DUMP.
                I downloaded latest BIOS from Fujitsu (for V2030) and flashed it as per instructions. After doing so the laptop has become unstable, I'm getting lots of BSODs, CRC errors, etc, and I didn't make a backup.
                I am unsure what difference, if any is between the V2030 and V2030D, but mine is the V2030D.
                The BIOS I flashed was 1.0H.
                Thank you
                09-29-2025, 11:43 PM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
