Fujitsu E459 Bios Dump
  • Repdata
    • May 2020
    • 67
    • Deutschland
    Hello
    After a bios update of my Fujitsu E459, the USB ports no longer work
    in bios will too
    MCU version no connection information is displayed
    I am thankful for every help
  • lapfix
    • Mar 2020
    • 2744
    • my workshop
    Re: Fujitsu E459 Bios Dump
    Originally posted by Repdata
    Hello
    in bios will too
    try
    • Repdata
      • May 2020
      • 67
      • Deutschland
      @Lapfix
      Thank you very much I will give you feedback
      @lapfix
      USB ports work
      Thanks again
      Unfortunately, I was happy too early, the M2 is no longer recognized
      • hoaca388
        Badcaps
        • Jan 2022
        • 11906
        Lifebook e459
          • 21218
          try this one.
          • Repdata
            • May 2020
            • 67
            • Deutschland
            thank you I will test and give feedback
            • Repdata
              • May 2020
              • 67
              • Deutschland
              I tested both files
              Unfortunately, the USB ports do not work
              thanks for the work
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • EGUG
                Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
                by EGUG
                I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
                Serial number EICK023345
                Mainboard D3823-A2
                Hope somebody can help me.
                04-10-2025, 02:05 AM
              • haitham sharabati
                [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                by haitham sharabati
                Hello engineers 😀,
                I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                💀 Problem:😅
                - Device shows “Administrator Password”...
                08-07-2025, 04:54 AM
