Original Bin Files for Many Macbooks Chips U2890, UB090, U3060, UB260, UF260
  • Raimisz
    • Feb 2014
    • 27
    • Lithuania
    Also have a known working A2442 820-02098-A UG260 BIN file.
    • toniblank
      • Aug 2018
      • 26
      • indonesia
      820-00138 U2890 tested
      this is usb c firmware bios NOT main bios. if u dont understand please do not download those files!
      many thanks for PACh
      • Odeinkantar
        • Sep 2016
        • 5
        • Indonesia
        Thanks...!!! Great!
        • laptech
          • Sep 2014
          • 25
          • pakistan
          very good nice
          • joen_d66
            • Apr 2013
            • 66
            • jakarta
            Originally posted by PACh
            Hi everybody, here are the Original BIN Files for the following Macbooks Chips, I hope it helps somebody
            A1706 820-00239-A UB090
            A1706 820-00923-A U2890
            A1706 820-00923-A UB090
            A1707 820-00281-A U2890
            A1707 820-00281-A UB090
            A1707 820-00928-A U2890
            A1707 820-00928-A UB090
            A1708 820-00840-A U2890
            A1708 820-00875-A U2890
            A1932 820-01521-02 U2890
            A1989 820-00850-A U2890
            A1989 820-00850-A UB090
            A1990 820-01041-A U2890
            A1990 820-01041-A UB090
            A1990 820-01814-01 U2890
            A1990 820-01814-01 UB090
            A2141 820-01700-A U2890
            A2141 820-01700-A UB090
            A2159 820-01598-A U2890
            A2179 820-01958-A U3060
            A2251 820-01949-07 U3060
            A2251 820-01949-07 UB260
            A2289 820-01987-06 U2890
            A2337 820-02016-A UF260
            A2338 820-02020-A UF260
            useful dump..maybe will need this later.. 👍🏻
            • joen_d66
              • Apr 2013
              • 66
              • jakarta
              #26
              Originally posted by Raimisz
              Hello everyone. I would like to add to this collection a known working A2485 820-02100-A UF260 BIN file. Also, maybe somebody have a BIN file for this board from UG260?
              thanks..need this one for compare with A2442
              • joen_d66
                • Apr 2013
                • 66
                • jakarta
                #27
                you saving me.. thanks a lot
                • buddyrock85
                  • Oct 2016
                  • 4
                  • indonesia
                  #28
                  thanks brother
                  • farman_0019
                    • May 2014
                    • 4
                    • india
                    #29
                    THANK YOU
                    • mon2
                      • Dec 2019
                      • 14240
                      Adding another bios for A1708 820-00840.
                      • dclass-pro
                        • Dec 2022
                        • 157
                        • Italy
                        #31
                        I installed this bios and it finally started working 100% again THANK YOU!!!
                        • bcherdak
                          • Oct 2017
                          • 5
                          • usa
                          #32
                          Hello does anyone have the UF260 firmware for the A2338 M2 model?
                          The logicboard # is 820-02773.
                          The USB-C chip for the A2338 M2 is a CD3217B13 and not CD3217B12
                          is the UF260 rom the same as the A2338 M1?
                          • bcherdak
                            • Oct 2017
                            • 5
                            • usa
                            #33
                            Here is the UF260 bin file for the M2 Macbook Pro A2338 (for the cd3217b13 chips)
                            • Om Om
                              • May 2025
                              • S
                              #34
                              Hello, do you have A2337 U1970 dump file? If you have can you post the link to download it please, because my MacBook M1 is stuck at 5V and 0.032A
                              • samolo75
                                UB090 from faulty 820-01814-A
                                by samolo75
                                Here it is the original rom from this macbook mother board with a very strange behavior. I included the A1990 UB090 file that I found here in the forum, thanks for that. I can see that the content of the files is different, probably too different for just being than mine got a bit corrupted.
                                The behavior is that al four USB C ports negotiate the 20V completely fine and the computer boots. Connecting a USB hub, the sd card reader works, the Ethernet port works, HDMI works, but connecting a simple mouse does not work. The working functions of the USB Hub mentioned only work on the...
                                06-03-2023, 03:53 AM
                              • ronaldopdias
                                820-00293 - No power - Stuck on 5v 0.06A
                                by ronaldopdias
                                Board Model: 820-00923
                                Issue: Board takes 5V @ 0.694A on all ports. No signs liquid.
                                Customer stated: Died during an update whilst battery was at 10%. Tried plugging in but it died.
                                Board takes 5V at 0.06A on all USB-C ports..
                                Board is clean with no visible corrosion or liquid damage.
                                PP1V8_UPC_TA_LDOA - 1.8V
                                PP3V3_UPC_TA_LDO - 3.32V
                                PP1V8_UPC_TA_LDOD - 1.8V
                                PP1V1_UPC_TA_LDO_BMC - 0V
                                PP1V8_UPC_TB_LDOA - 1.8V
                                PP1V1_UPC_TB_LDO_BMC - 0V
                                PP1V8_UPC_TB_LDOD - 1.8V
                                PP3V3_UPC_TB_LDO - 3.28V
                                05-30-2025, 06:49 AM
                              • ronaldopdias
                                820-00850 that is stuck on 5V at 0.294A
                                by ronaldopdias
                                Hi everyone. I need a help with this Mac, please.
                                T
                                he logic board shows no signs of life , is clean with no liquid damage, and is stuck at 5V and 0.294A on all ports.
                                DFU attempted, but it stalled halfway through the system installation.
                                Mac turns on with a working battery, but doesn't charge it.
                                With a Working battery the voltages are 20V at 0.0300a
                                PPBUS_G3H - 12.28V
                                XB, XA, TA, TB are all measuring same voltage.
                                PP20V_USBC_XB_VBUS - 5V
                                PP3V3_UPC_XB_LDO - 3V
                                PP1V8_UPC_XB_LDOA - 1.8V
                                PP1V8_UPC_XB_LDOD -1.8V...
                                02-15-2025, 08:00 AM
                              • Joyoungjae
                                a2141 820-01700 charge only with one port
                                by Joyoungjae
                                Hello friends, it's been a while.
                                Model A2141 came to me for repair.
                                I confirmed that there was a short in the ppdcin line and that the capacitor was blown.
                                All the short line capacitors seemed to be in bad condition, so I replaced all c7043, c7024, c7026, c7027, c7029, and c7042.
                                The short is caught and the power is turned on.
                                However, when the power is turned on with the battery installed, only one charging port works and the other three display 20V but 0 amps.
                                If you plug in the charger when the battery is not installed...
                                07-31-2024, 05:27 AM
                              • msnessay
                                i need dump type c Rom U2890 820-00281-A
                                by msnessay
                                i need dump type c Rom A1707 touchbar 15 inch
                                U2890 W25Q80 1mo
                                820-00281-A
                                04-11-2022, 11:58 AM
