Original Bin Files for Many Macbooks Chips U2890, UB090, U3060, UB260, UF260
  • Raimisz
    • Feb 2014
    • 27
    • Lithuania
    Also have a known working A2442 820-02098-A UG260 BIN file.
    • toniblank
      • Aug 2018
      • 27
      • indonesia
      820-00138 U2890 tested
      this is usb c firmware bios NOT main bios. if u dont understand please do not download those files!
      many thanks for PACh
      • Odeinkantar
        • Sep 2016
        • 5
        • Indonesia
        Thanks...!!! Great!
        • laptech
          • Sep 2014
          • 25
          • pakistan
          very good nice
          • joen_d66
            • Apr 2013
            • 66
            • jakarta
            Originally posted by PACh
            Hi everybody, here are the Original BIN Files for the following Macbooks Chips, I hope it helps somebody
            A1706 820-00239-A UB090
            A1706 820-00923-A U2890
            A1706 820-00923-A UB090
            A1707 820-00281-A U2890
            A1707 820-00281-A UB090
            A1707 820-00928-A U2890
            A1707 820-00928-A UB090
            A1708 820-00840-A U2890
            A1708 820-00875-A U2890
            A1932 820-01521-02 U2890
            A1989 820-00850-A U2890
            A1989 820-00850-A UB090
            A1990 820-01041-A U2890
            A1990 820-01041-A UB090
            A1990 820-01814-01 U2890
            A1990 820-01814-01 UB090
            A2141 820-01700-A U2890
            A2141 820-01700-A UB090
            A2159 820-01598-A U2890
            A2179 820-01958-A U3060
            A2251 820-01949-07 U3060
            A2251 820-01949-07 UB260
            A2289 820-01987-06 U2890
            A2337 820-02016-A UF260
            A2338 820-02020-A UF260
            useful dump..maybe will need this later.. 👍🏻
            • joen_d66
              • Apr 2013
              • 66
              • jakarta
              #26
              Originally posted by Raimisz
              Hello everyone. I would like to add to this collection a known working A2485 820-02100-A UF260 BIN file. Also, maybe somebody have a BIN file for this board from UG260?
              thanks..need this one for compare with A2442
              • joen_d66
                • Apr 2013
                • 66
                • jakarta
                #27
                you saving me.. thanks a lot
                • buddyrock85
                  • Oct 2016
                  • 4
                  • indonesia
                  #28
                  thanks brother
                  • farman_0019
                    • May 2014
                    • 4
                    • india
                    #29
                    THANK YOU
                    • mon2
                      • Dec 2019
                      • 14244
                      Adding another bios for A1708 820-00840.
                      • dclass-pro
                        • Dec 2022
                        • 157
                        • Italy
                        #31
                        I installed this bios and it finally started working 100% again THANK YOU!!!
                        • bcherdak
                          • Oct 2017
                          • 5
                          • usa
                          #32
                          Hello does anyone have the UF260 firmware for the A2338 M2 model?
                          The logicboard # is 820-02773.
                          The USB-C chip for the A2338 M2 is a CD3217B13 and not CD3217B12
                          is the UF260 rom the same as the A2338 M1?
                          • bcherdak
                            • Oct 2017
                            • 5
                            • usa
                            #33
                            Here is the UF260 bin file for the M2 Macbook Pro A2338 (for the cd3217b13 chips)
                            • Om Om
                              • May 2025
                              • S
                              #34
                              Hello, do you have A2337 U1970 dump file? If you have can you post the link to download it please, because my MacBook M1 is stuck at 5V and 0.032A
                              • samolo75
                                UB090 from faulty 820-01814-A
                                by samolo75
                                Here it is the original rom from this macbook mother board with a very strange behavior. I included the A1990 UB090 file that I found here in the forum, thanks for that. I can see that the content of the files is different, probably too different for just being than mine got a bit corrupted.
                                The behavior is that al four USB C ports negotiate the 20V completely fine and the computer boots. Connecting a USB hub, the sd card reader works, the Ethernet port works, HDMI works, but connecting a simple mouse does not work. The working functions of the USB Hub mentioned only work on the...
                                06-03-2023, 03:53 AM
                              • msnessay
                                i need dump type c Rom U2890 820-00281-A
                                by msnessay
                                i need dump type c Rom A1707 touchbar 15 inch
                                U2890 W25Q80 1mo
                                820-00281-A
                                04-11-2022, 11:58 AM
                              • dellxps15
                                820-01041 stuck on 5volt 220mah
                                by dellxps15
                                hi all, got this board not powering on. it has 4 usb-c port and at start i got this situation:
                                1 usb of each side was on 5 volt and 120mah drain, and 1 usb of each side had 5 volt and 480mah.
                                after replacing 2 usb of same side cd3215C00 (should be ok) i had 5 volt and 120mah on all port, but on other side of replaced cd3215 i had one port not worning if cable was inserted one way ( work just opposite side cable)
                                after another inspection i see one usb not giving PP3V3_UPC_XB_LDO and usb-c getting hot, so replaced the other 2 usbc and finally now i have...
                                01-14-2023, 12:43 PM
                              • wnt2fx
                                A1989 (820-00850) - 5V@0.23A - shorted usbc cable
                                by wnt2fx
                                dear fellow tech enthusiasts, I would appreciate your help ! I have an 820-00850 here that died on a squeezed/shorted charging cable.
                                I found several shorted ldo's on both U3100 and U3200. I replaced them with cd3215c00 ( originally c00Z )
                                D3301 was shorted, removed without replacement for now. No other visual / obvious findings. ports look good.
                                4,86V / 0,23A on usbc meter and ppbus 12.28V, ppdcin_g3h 5V and pp3v3_g3h 3.3V - all ports/orientation. Nothing obvious on a thermal picture, only t2 warms up to 35Celsius.
                                1V1 LDO missing on u31/32...
                                09-20-2022, 02:02 AM
                              • powerblackout
                                820-00923-A No left side USB activity
                                by powerblackout
                                Board couldn't boot due to corrosion under UB090, stuck at 5v 20-30mah. After cleaning that up the board boots and charges, 20V on all 4 TB ports.
                                Trackpad and keyboard currently don't work due to a failed battery swap that left gouges in the trackpad board exposing traces. Touch bar doesn't work either, haven't started troubleshooting that.
                                USB devices aren't detected on the JB500 connector. any orientation, either of the ports. Tried known working flex connector. When using an ammeter I see no power flowing out to the USB device, when connected to J3300 5V 200mah goes...
                                01-01-2023, 11:30 PM
