Surface Go 1943 bios
  • peste
    • 12729
    • ROMANIA
    Originally posted by ishfaq
    can someone help me to unlock this bios
    post S/N, full name and model, motherboard model, etc.
    • ishfaq
      • Sep 2016
      • india
      Model:-Surface laptop go 1943
      SN#020464513766
      DA0Z91MBAE0
      • hoaca388
        Badcaps
        • Jan 2022
        • 11685
        SN#020464513766
        DA0Z91MBAE0
        • ishfaq
          • Sep 2016
          • india
          hoaca388​#
          Thank You So Much Working Perfectly
          • gjlpereira
            • Sep 2018
            • 11
            • Portugal
            Hi.
            I'm dealing with a persistent boot issue on a Surface Laptop Go (Model 1943) after a motherboard replacement.
            The original motherboard was burn to a crisp (CPU power rail burn a hole in the motherboard); so I got myselft a replacement but din't manage to get it working yet.
            Situation:
            • Original SSD was BitLocker-encrypted.
            • Motherboard was replaced with a (supposedly) known-good donor board.
            • Device powers on, shows Windows logo, but gets stuck — no spinning dots, no activity.
            • Cannot enter UEFI (Volume Up + Power does nothing).
            • Cannot boot from USB (Volume Down + Power also hangs).
            • Without an SSD present, the board doesn’t power on (normal for Surface?).
            What I’ve tried:
            • Swapped in a brand-new blank SSD → same result.
            • Wiped original SSD externally → same result.
            • Created official Surface Recovery USB → no boot.
            • Flashed BIOS from (unknown) donor board → no change.
            • Swapped BIOS chip from the original board → still stuck.
            • Tried multiple UEFI/boot key combos.
            Has anyone dealt with a similar Surface firmware hang like this?
            Cloud this be a ME firmware mismatch or missing?
            Could the original BIOS be corrupted or have missing contents?
            Attached I'm sending the BIOS dump from the new motherboard. If anyone could have a look at it and a possible fix that would be much appreciated.
            • peste
              peste commented
              Editing a comment
              post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • gjlpereira
            • Sep 2018
            • 11
            • Portugal
            #26
            Hi, just to clarify — I didn’t actually ask for a BIOS password removal. My request was something completely different, which is why I created a new topic. I’m asking for a BIOS integrity check on a donor board, not for password removal. Thanks!
              • 20781
              The word password has been edited out of the thread title now, so your post is ok here. How many seconds does it stay on the logo for, do you see a slight flicker after 1-2 seconds with the logo carrying on for a few seconds more
              • AustinJames-Atkins
                • Jul 2025
                #28
                Does anybody know how I can recover a bad BIOS on a surface 1943?. What are the steps I need to do and does anyone have a UEFI/ BIOS file that I can flash.
                • peste
                  • 12729
                  • ROMANIA
                  #29
                  The bios chip must be unsoldered from the board before writing or reading..
                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                  solder wires between the programmer and the bios chip..
                  you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                    • Jul 2025
                    #30
                    Cheers for the heads up on this, just one question, where can I get the UEFI/ BIOS file from to write it to the chip? Also where is the BIOS chip located and what is its markings?.
                    I am new to this particular make and model of device, and appreciate all the information I can get with regards to this.
                    Kind regards and thanks again
                    Austin.
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • traxformania
                      TONGFANG "GM7TG7P" Bios Password Problem?
                      by traxformania
                      I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                      But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                      I'm trying to reset my bios without success.
                      I tried :
                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                      11-15-2023, 07:32 AM
                    • tlindi
                      Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                      by tlindi
                      Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                      >Read BIOS guides, methods, resources and tools
                      Ack
                      >Try the method at BIOS guides, methods, resources and tools before requesting help
                      Ack
                      >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                      python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                      01-30-2025, 04:26 AM
                    • Nopslide
                      HP Omen 15-dh0052nf power-on & bios password
                      by Nopslide
                      Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                      My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                      Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                      04-01-2024, 04:27 PM
                    • BlackVisor
                      How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                      by BlackVisor
                      RedmiBook Pro 1542022 6800H
                      SKU: TM2113-39463
                      Model Number: RMA2204-AB
                      CMIIT ID: 2022AP1835
                      SN: 39463/22WD01355
                      BIOS version: RMARB5B0P1010 20230628
                      1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                      2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                      3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                      01-14-2024, 06:35 AM
