Dell Latitude 5420 Bios Password 8FC8
+ More Options
Posts
  • koba71786
    MatrixUser
    • 7
    • Georgia
    #661
    Originally posted by koba71786
    thanks, but..
    i have neoprogramer software
    i write this unlock bios and The laptop won't turn on
    It doesn't turn on at all, when I turn on the power supply, only then the light turns yellow, and nothing turns on.
    what can i do
    The bios chip is alive, the programmer reads it
    Can anyone help me what to do?
    • alfredposadas09
      • Aug 2020
      • 343
      • Philippines
      #662
      buy better programmer such as rt809f flashing yellow lights indicated bios failure
      • alfredposadas09
        • Aug 2020
        • 343
        • Philippines
        #663
        you can revive it back using known good bios yet there is some problem such as slow perforamnce camera not working keyboard backlight not working.. so unlocking the orig file is the best move.. and next time make atleast 3backup(click read and save not copy paste) before erasing the chip
        • alfredposadas09
          • Aug 2020
          • 343
          • Philippines
          #664
          check if u solder the bios properly sometimes its only a bad solder..
          • koba71786
            MatrixUser
            • 7
            • Georgia
            #665
            where to find good bios? for me?to revive it?
            solder the bios properly everyting is ok
            • CraterM
              • Mar 2018
              • 178
              • Moldova
              #666
              Rules: Always read two times and compare with hxd to exclude other problems and time. When the two files are identical, only then go to the next step!
              • DT523
                • Mar 2024
                I have a Latitude 5420 8FC8 that I need to remove the BIOS lock. What do I need to do?
                • alfredposadas09
                  • Aug 2020
                  • 343
                  • Philippines
                  #668
                  Reas bios using bios programmer
                  • wwbielsko
                    • Aug 2008
                    • 59
                    #669
                    Dell latitude gdf40 la-k491p
                    ADMIN PASSWORD please help unlock
                    OK i made it sorry, post for delete
                    • trunguntilyou
                      • Aug 2022
                      • 328
                      • Vietnam
                      #670
                      help pls remove computrace lock!
                      thank all!
                      st : BTZ14F3 and C50N4M3
                      • minhdigital
                        • Nov 2022
                        • 756
                        • Vietnam
                        #671
                        thank all!
                        Send to you
                        • trunguntilyou
                          • Aug 2022
                          • 328
                          • Vietnam
                          #672
                          Originally posted by minhdigital
                          Send to you
                          works perfectly ! Thank you comrade
                          • Phcunha
                            • Apr 2024
                            • Brazil
                            #673
                            Can someone help me unlock dell latitude 5420???
                            • CraterM
                              • Mar 2018
                              • 178
                              • Moldova
                              #674
                              Post dump + information. Read rules!
                              • Neves Mitt
                                • Apr 2024
                                • Namibia
                                #675
                                Hello, can someone help unlock bios/admin password on Dell 5420, nothing is working, no USB ports nothing.
                                • Neves Mitt
                                  • Apr 2024
                                  • Namibia
                                  #676
                                  Where do I get the post dump and other info
                                • srsyed1
                                  • Mar 2024
                                  • 20
                                  • United kingdom
                                  #677
                                  Hi please help me with remove bios password
                                  st# 7s742j3
                                  • m.sabry2110
                                    • Oct 2017
                                    • 129
                                    • egypt
                                    #678
                                    st# 7s742j3
                                    try
                                    • srsyed1
                                      • Mar 2024
                                      • 20
                                      • United kingdom
                                      #679
                                      Originally posted by m.sabry2110
                                      try
                                      Thanks it work perfect.
                                      • TERKO37
                                        • Mar 2021
                                        • 8
                                        • mexico
                                        #680
                                        can you unlock this bios please
                                        DELL 5420
                                      • gizaha
                                        by gizaha
                                        02-13-2024, 07:18 AM
                                      • jhanra
                                        by jhanra
                                        11-02-2024, 04:19 AM
                                        DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
                                        09-07-2024, 06:31 AM
                                        09-07-2024, 03:40 AM
