Need BIOS Dump Lenovo ideapad 1002-14IBR
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Need help guys Bios dump for Lenovo ideapad 100S-14IBR
    all voltage are present. bios voltage is 3.3v
    motherboard is E162264
    eeprom winbond 25x40clsig 512Kb
    attached is the bios dump. thanks in advance
  • DanielDacko
    • Mar 2015
    • 325
    • Macedonia
    Re: Need BIOS Dump Lenovo ideapad 1002-14IBR
    This is not bios dump, it should be 8MB.
    Try this.
    I don't provide help for people using CH341A and a clip.
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Sorry for that..its a EC.bin file..my bad
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        Try this.
        Thanks for the dump and ec bin
        • GOSA123
          • Aug 2024
          • Великобритания
          Thanks allot !!! I loking this dump two weeks, THANK YOU!!!
          • jendkkd jeje
            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
            by jendkkd jeje
            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
            10-11-2024, 03:12 PM
          • joven016
            Lenovo Ideapad S145 need working bios HELP!!
            by joven016
            Problem is blinking power led only
            i don't know exactly if it's s145-15igm or s145-14igm
            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
            Already tested some of posted bios here
            S145-14igm - success but invalid serial and not booting on OS
            S145-15igm - success with serial and some other info in bios but still not booting on OS
            already tried installing new windows but always booting on bios setup
            windows installer flash drive detected on...
            08-21-2025, 10:55 PM
          • AHmad_Salal
            Need BIOS Dump/ROM for Lenovo Thinkstation p500
            by AHmad_Salal
            Hello all,
            I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
            11-28-2023, 05:28 AM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • mximiliandz
            help bios lenovo ideapad s145-14iil type 81w6
            by mximiliandz
            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
            06-20-2025, 06:50 AM
