need bios thinkbook 16 G2 ITL FLV35 LA-K052P REV 1.0 plz
tryAttached FilesComment
thanks man, unfortunately it seems to not work. Light comes on when power button is pressed then goes off after 3-5 seconds then comes on and keeps doing that. Am I supposed to do something else other than write the files? Also one thing I noticed is the 8mb chip i can't erase it says "WARNING, probable erasure failure." so I just wrote the new file without erasing. This could be the issue but I've nver encountered this error before.
thanks man, unfortunately it seems to not work. Light comes on when power button is pressed then goes off after 3-5 seconds then comes on and keeps doing that. Am I supposed to do something else other than write the files? Also one thing I noticed is the 8mb chip i can't erase it says "WARNING, probable erasure failure." so I just wrote the new file without erasing. This could be the issue but I've nver encountered this error before.Comment
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by HotSaladMan*##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
Model : Lenovo ThinkBook 14S Yoga ITL
S/N : MP28JT19
MFG Date : 2022/02/09
Factory ID PRC4
MO : MPNXB26080FX
MTM : 20WE001US
MODULE FCC ID : PD9AX201NG
IC : 1000M-AX201NG
BOARD INFO
FLV34 LA-KO51P
REV : 1B 2020-08-24
Bit of Info
Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
chip id, so i would always uncheck the id check, so it would bypass the error
i did in fact make...-
by Chris2025Hello BIOS gurus,
Laptop in trouble is:
model: ThinkBook 14p G2 ACH
MO: PF9XB1C20495
MTM: 20YN0023AU
SN#: PF3GVSPN
Current issue: laptop react on power button, battery charging, fan turning on/off, no CAPS LOCK response on pressing, no system boot and screen remains black.
What was done so far - connected external monitor via HDMI / USB-C, system reset, BIOS reset - all to no avail.
Also loaded random BIOS for this model from internet - PC booting up but have odd issues when I try to reinstall Win11 on it.
Would...-
- Loading...
