dell 5502 manufacturing mode - HELP -
  • electronica
    • Apr 2014
    • 86
    • algeria
    hello friends i have 2 dell laptops 15 5502 with admin password . i unlocked the first one but for the second one i lost the original bios file so i used the file from the first one (after cleaning the me) the laptop start normally in manufacturing mode so i press fn key + f or x and enter the service TAG
    and when i reboot everything is gone the laptop return to the manufacturing mode with an empty service tag field. i tested so many bioss and versions with no luck . if someone had same problem or a solution . thank you
  • volinakis
    • Jan 2021
    • 2666
    • N/A
    Re: dell 5502 manufacturing mode - HELP -
    press Alt+F
    • electronica
      • Apr 2014
      • 86
      • algeria
      Originally posted by volinakis
      press Alt+F
      hi i pressed every possible combination .
      • Manjunathrawoor
        MBR
        • Mar 2021
        • 42
        • India
        Flash OEM Bios and press ALT-F it will work
        • electronica
          • Apr 2014
          • 86
          • algeria
          sorry what dose mean OEM bios ?
          • electronica
            • Apr 2014
            • 86
            • algeria
            reup
            • jlxxxx
              Dell 9310 (2-in-1) bios to fore manufacturing mode
              by jlxxxx
              I have read the FAQ, and other reference here to changing the EC region of the flash image to force entering manufacturing mode.
              How would I modify the dell 9310 firmware in order to force entering manufacturing mode? The goal is to have the computer ask me to enter the service tag after changing the motherboard.
              Can this be completed using the boot-up USB restore method that Dell supports in order to reduce risk of damaging the hardware further? (Ctrl+Esc keys while holding the power button)
              Dell provides this bios here: https://www.dell.com/support/home/en-us/drivers/dri...
              09-25-2024, 02:38 PM
            • CapThatBrass
              The Mystery of 'Manufacturing Mode' - Dell Motherboards
              by CapThatBrass
              Firstly sorry if this is the wrong forum for posting this question - please recategorize or move to another part of the forum if necessary.
              I've been doing alot of research recently into the world of BIOS editing and building of images, out of curiosity mainly.
              Lots of Youtube videos as well as threads in this forum (as well as others) mention the term 'unlocked' bios which generally means the removal of BIOS passwords from a dumped image to allow full access to the BIOS/UEFI menu. However, a handful mention that a prompt for the Service Tag will...
              11-04-2022, 04:59 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • CapThatBrass
              Dell Latitude 3420 BIOS - Manufacturing Mode Required
              by CapThatBrass
              I'm having some issues with a Dell Latitude 3420 laptop I'm working with. The chip itself is an XMC25RH256CXIQ but I've not been able to find the exact settings for this chip using NeoProgrammer.
              Instead, I've made a dump of the image using the following three chip settings within the software:
              - XC25QW256C
              - W25Q256BV
              - MX25L25635E
              All three images have been uploaded. Oddly enough all three images aren't identical, but I'm guessing that the XMC XC25QW256C version might be the closest match.
              If someone...
              06-11-2022, 03:48 PM
            • maximuslobo
              Dell DC IN connector name for the dell 5502/5509
              by maximuslobo
              Hi
              whats the name of then Dell DC in connector name for the dell 5502/5509
              12-09-2024, 06:31 PM
