Dump Asus FX706HC
  • husniddin
    • Jan 2017
    • 98
    • Uzbekistan
    Dump Asus FX706HC
    Hi Guys, I need bios dump clear ME, for laptop Asus FX706HC motherboard DANJJMB1AA0.
    My backup bios.
    Thank you
  • pityulix
    • Nov 2021
    • 30
    • Targu-Mures
    Hi Folks,i need some help to clean me on my bios chip,i replaced PCH,Thank you a lot.Best Regards
    Laptop Model FX706HC-HX007W
    SN: MBNRCX06H683487
    CN DH5 24M
    Motherboard: DANJJMB1AA0 Rev.A
    • mohamedbalwe
      • Jan 2021
      • 51
      • aleppo
      HELLO EVERY ONE
      I NEED BIOS GPU gn20-p0-a1 rtx3050
      motherboard DANJJMB1AA0 rev a
      this file bios dump GPU BIOS AND MAIN BIOS
      SN M9NRCX042691387
      ASUS FX706HC
      LAPTOP proplem in gpu card code error 43
      mats and mods dont detect gpu before before change bios
      after change bios mats and mods detect gpu and test memory but error in all memory im not sure that the file bios
      • peste
        peste commented
        Editing a comment
        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
    • mohamedbalwe
      • Jan 2021
      • 51
      • aleppo
      peste
      sir i need file for bios gpu im serch ididnt find it
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
